Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
There have been discussions on the forum where the suggestion has been made to disconnect the 12V battery in order to "reset" some function of the vehicle that was not performing properly (TCU comes to mind for the '23 model owners). I realize that disconnecting the 12V battery is probably easier than finding the fuse for the offending module and just pulling that for a few minutes instead.
But it may be creating a different problem. There is a Battery Monitoring System (BMS) that keeps track of your 12V battery status and lets the BMS know when the battery is fully charged. Disconnecting the 12V battery can screw up the "learned values" in the BMS and then your 12V battery may not fully charge after that.
The fix for this issue is simple and techs are told to do this everytime they replace a battery or the FDRS program they use indicates that the battery state-of-charge is too low. It's a procedure that can be done in FDRS or with this simple routine that can be done before the next time you take a drive.
Press the start button without stepping on the brake (Accessory mode).
Flash the highbeams with the stalk 5 times, and then step on the brake pedal 3 times, and after that check the red battery icon on the instrument panel to see that it flashes three times.
And then press the start button again to turn the truck off.
And then you can turn the truck fully on and drive off. Your 12V battery should then fully recharge.
