Installing a transformer in my truck
Dylanch
Dylan
Maple creek
F150
Because I have specific high power draw loads I needed more amps at 120v. So I rigged up a 250-120v transformer to double my output.
It works flawlessly just starting to build a rig to carry it around transformer is around 150lbs
We were able to run out cement mixer that needs a dedicated 20amp circuit. We tried to run it off the 120v lines from the truck and it would flip the breaker instantly.
By using 240v from the truck I'm using both inverters to run my 120v load
Ford F-150 Lightning Installing a transformer in my truck 20230804_084833
Ford F-150 Lightning Installing a transformer in my truck 20230803_154530
Ford F-150 Lightning Installing a transformer in my truck 20230804_085352
Ford F-150 Lightning Installing a transformer in my truck 20230802_093525
Ford F-150 Lightning Installing a transformer in my truck 20230804_085250
Ford F-150 Lightning Installing a transformer in my truck 20230802_112407
Damn - somebody actually using one of these trucks to work. I can't let my truck see this. Just a garage princess.
Pipefitter
2022 F-150 Lightning Lariat ER, 2024 Mach E Prem..
Wow, very impressive! Great to see the truck living up to the hype. Thanks for sharing the pictures.
mparz00
Capital District, NY
'22 Lightning Lariat ER, VW ID.4 AWD Pro
Telecom network construction
Dylan, wondering if you tried running the mixer off 1 leg of the 240v outlet since it's rated at 30A. I haven't tried it on the Lightning, but have used a 240v generator outlet to run 120v trailer this way. That would avoid the need for a transformer.
snowy_91
James
Aurora, SD
2023 Lightning XLT SR, 2024 Blazer EV
This post should be a standalone ford brochure.... it explains the advantage of an electric truck perfectly.
Dylanch
Dylan
Maple creek
F150
It doesn't work starting current is to high
Probably cheaper to fix/upgrade/replace the mixer.
If it's a 120v unit it should run on the outlet but it's obviously drawing too high a load, maybe start cap is gone?
mb0220
Matt
2022 Lariat ER
This is a cool idea. I come close to tripping the 120v outlet when I use an electric pressure washer. (it does trip when I add a 200w pump on the same extension cord.) Would be nice to have more amps available.
mb0220
Matt
2022 Lariat ER
This is true - and an interesting fact about the ProPower system. Even though they are fed by the same "circuit", each of the 120v legs is limited to 20 amps (16 sustained, 1,920 watts), but the 240v line which uses both of the legs has the full 30 amps available (24 sustained, 5,760 watts).
Bigisland Guy
Ed
So Cal
Retired Old Dude
Mahalo Plenty, for sharing! You found my solution to my 120V high start-up tool problems was always wondering if it was a practical solution.
Dylanch
Dylan
Maple creek
F150
It's mixing concrete even a new mixer will still pull alot when mixing. The only other option was to replace with a 240v motor but that would make it difficult everywhere else to get power
