lSherlockl
Wisconsin
F150 Lightning Pro 22'
Yeah, wrote the same aside from the heated steering wheel stuff.
yeah I'm betting its the same boat of that module has ICE firmware on it which will not interface properly with the lightnings "heating & cooling" for lack of better term.
Your hvac module is newer though, its possible you may be able to flash over the lightning firmware I was unable to do this with my module as firmware was not compatible (basically software id checks and checksums). But I think its a bit of a longshot, however if that is indeed the part that they retro fit on lightnings that tells me that ford service must be re-flashing the module somehow (though i personally still doubt it a little as that is listed as a ICE module)
jdmackes
2023 F-150 Lightning Pro
I'm guessing that it is just for ICE, I figured it would be for XLT lightnings also, not realizing that they can't have cooled seats. Ah well, if I have to switch back to the old module I will, just didn't want to have to use the software workaround for the heated wheel...
lSherlockl
Wisconsin
yeah me either if you want to muck around with flashing firmware you could maybe try that but it was a bit of jumping thru hoops to get a version of forscan that supported flashing the BEV hvac module.
I'm like 80% sure the hardware is the same and its just different firmware but its just out of our reach to get it working.
jdmackes
I don't even know how to get the firmware to even try it out. Only time I flashed firmware I was given the files by someone on the forum
lSherlockl
Wisconsin
I can share the stock BEV module files if it helps, do you have a paid version of forscan? i can probably also help with a link to a version of that too if you want to try it.
jdmackes
Yeah, I got that when I did the passive entry firmware flash. If you have the stock module files I'd appreciate it!
lSherlockl
Wisconsin
I will PM you sometime here after work, with files/info
jdmackes
Well, I've switched back to the original hvac unit for now and wanted to go ahead and set up the heated steering wheel with it, but it won't let me write anything to it anymore. Odd issue, not throwing any DTC's
lSherlockl
Wisconsin
its the version of forscan you need one of the beta or test ones as stock wont write to lightning hvac modules
jdmackes
Ah. I was running an older test one that would let me do the firmware updates; just tried to update to the new stock but that didn't work either. I'll reach out to them then. Thanks!
lSherlockl
Wisconsin
sent you a PM with links
jdmackes
With the test version of Forscan everything worked and I was able to get the heated steering wheel working, thank you! I opted to switch off the climate bar for now and see how it goes with the steering wheel coming on automatically (which it does do, so that's nice). I'll see about flashing firmware on to the other HVAC controls this weekend, but at least it's working!
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
I swapped this out about a month after I got my truck in September 2022.
From what I remember, restoring the config as is from my stock HVAC module the new one didn't work at all. I manually made most of the changes by comparing the spreadsheets from ICE to Lightning and it seems like it's been working fine for over a year. Defrost, AC, Heat, HSW all works.
I have backups of the forscan reads from my stock HVAC module, this stock HVAC module, and the changes I made. I can upload them if interested.
I have seats out of an ICE Lariat that I'm in the process of swapping in so I can't say for certain if HC seats will work yet.
Ford F-150 Lightning 2022 Lightning Pro Seat Swap/Upgrade to Heated/Cooled 1702524712346
3rdgenfan
Geoff
Delaware
Cybersecurity
Have been thinking about trying to grab some seats from a Plat at some point so if you wind up having good luck with the heating/cooling then I'm all ears, in addition to knowing the secrets behind getting that hvac panel to work.
wighty
NY
I'd still love to do this but struggle with figuring out where to source seats (presumably from totaled cars) from around me.
