Settings don't stick
dothedew
Colorado
Anyone have an issue with settings not sticking. I think it started happening with a recent update?
Every day when I get in the car I have to turn on the air for passengers in the side and back, otherwise, it's only giving me air. Same with the 30 minute shutdown timer, I have to turn it off every day. It seems like settings are not sticking. Any ideas?
My TRUCKS passenger seat setting [warmer / cooling fan] has been intermittent for months, many times it immediately recognizes the passenger presence when they sit in the seat, other times it does not, I remind my wife to check and adjust if I haven't noticed and adjusted it for her, sometimes this takes 30-60 seconds for the system to adjust automatically.
The 30 minute shutdown timer is designed to always be active on every KEY ON cycle, if you want it off, then you need to turn it off.
invertedspear
AZ, USA
lightningcalcs.pages.dev
Same thing in my XLT (not sure what your trim is). It defaults to "driver focused" if it's been turned off long enough. I've gotten in the habit of checking it every time. If this is a feature, it misses the mark to assume I drive alone the majority of the time, or even if I do that I prefer the driver focus.
FirstF150InCasco
Boston MA
The setting that does not stick that bothers me the most is the 24 hour clock. It SAYS that it's on 24 hour clock, but it actually is not. I have to turn of 24 hour and turn it on again to get 24 hour clock to return.
What was your last power up ?
Mine has stabilized at 6.2.0
Ford Motor Company
Official Ford Account
F-150 Lightning
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
Amps
Bolt
If you use phone as a key, make sure your PaaK device is associated with, and logging you into your truck's profile.
