davehu
- Jan 7, 2022
- hot springs, AR
- 2023 Lighting Lariat ER, Iconic Silver
- Occupation
- retired
thank you very much.So I just wanna preface this by saying this simple yet genius solution was not my idea but rather sourced directly from the F150 14th Gen forum. Now that being said let's get into.
The Problem
The center console compartment door will barely stay up, if at all. If you're on anything but even, level ground, just forget it. That bad boy is slamming closed on your hand if you're not doing the elbow center console equivalent of the M1 Garand palm heel reload. The problem seems to be a lack of suffcient spring tension. For whatever reason whether it was poor design, bad supplier inventory or poor manufacturing tolerances and quality control, there isn't enough spring force to keep the door of the center console open.
