Android auto calls
Lightning Rod
The North Coast
2023 Ford Lightning Lariat ER
PROGRAMMER
Quick fix as noted is to switch between truck to handset and back. The other person can hear me, but I can't hear them. I just tell them to hang on a second while I make the switch over.
Same issues as well. Going to try this fix as this problem is getting really annoying.
Thanks.
Ford Motor Company
Official Ford Account
F-150 Lightning
Thanks.
Hi there. Will you send us a message with your VIN and dealership name/location? I can look into these android auto call concerns on my end. To send a private message, just click on our username and select "Start Conversation".
Tfarrell73
Tim
New Lenox, Illinois
23 F150 Lightning Lariat ER
Just tried AA yesterday to test Google maps directions. Got an incoming call today. I just heard static. Caller tried again tried answering still incoming static. They called 3rd time, this time I could hear them fine. Caller stated they could hear me on earlier tries but I couldn't hear them
GoodSam
Good
occupying space
How are you switching between truck and cellphone? Running Android Auto?
Android Auto running, Wired or wireless, our Moto G Power is just getting static when person that called or was called is speaking, also without being able to hear any ringing when calling out. This was not the case in 2023, but we are not doing a lot of calls so not able to pinpoint when problem started.
Also I tried turning off AA, so just Bluetooth I guess, and problem was same. Had to turn off truck and open door to have cellphone working directly to cell system to get a clear connection. Did not try display reset yet.
xwing
Okeana, OH
2023 F-150 Lightning
I'm just pressing the button on the screen to switch to the hand set and then press a second time to switch to the truck. I usually don't run android auto. I just connected to my Pixel 5A with bluetooth.
Basis0439
2023 F150 Lightning
I'm still having to manually switch between bluetooth and the phone in order to get bluetooth over the truck working.
What gives? Clearly the truck's capable of handling calls properly and it's just a software issue... why is something so basic as call handling failing?
GoodSam
Good
occupying space
@Lightning Rod @MRButtler @RRINN @JustaProGuy
Regarding the phone call static, I contacted Ford BEV 866-631-3788, transferred to BEV tech?, display reset did nothing. Tech, Kamera?, said software update coming for phone communication as this is a common issue. I cannot imagine having to deal with the INTENSE static-only called/caller's ring/voice, and thereby a lost call, if I used the phone every day.
Update 5-7-24: found my wife's Moto G Power, same as my model, does not have a problem with static substituting for voices. I did get a refurb exchange for a broken screen sometime in the past, so I wonder my unit has a defect. So now I must blame the phone instead of Ford. Now I still need to figure out periodic loss of Ford Nav (reset of phone helped?) and the shaky Ford Navigation arrow on the map.
Lightning Rod
The North Coast
PROGRAMMER
The static problem has mostly went away for me. What I don't like now, is when I'm driving in the truck and my phone rings, it will come through the speakers like normal, but now, the display will say, Unlock your phone when it's safe, or something like that. So I have to dig in my pockets to find my phone, then wake my phone up, just to answer the call. It's VERY dangerous! Before, all I had to do was to tap the Answer the call button on the truck display but I'm guessing a recent update screwed that up. *sigh*
Tradewind
Ryan
Atlanta, GA
2023 F-150 Lightning XLT
Communications/Meteorologist
2023 XLT, Pixel 5, same issues. I get one ring through the truck and then silence, and just like others have said, I switch to speaker or handset and then back to Bluetooth and the audio comes back. Good to know it's not just me or my phone.
Dyoung5573
Dustin
Minneapolis
Ford F150 Lightning
I'm having the same issue on my 2023 lariat. It's super frustrating and I can't find a fix at all.
GoodSam
Good
occupying space
newer phone, Moto G Stylus 5G 2024, fixed my problem, or at least the static is gone and connecting to AA is more consistent, but not perfect.
ColeCisneros
Cole
usa
BMW
developer
Had the same weird silence issue dialing through my car with Android Auto. Outgoing calls from the phone worked fine, incoming too, but using the car buttons was dead. Unpairing and re-pairing the phone fixed it for me. At work we run activecalls and seeing how smooth calls are there makes me wish car systems handled call routing just as cleanly—it’s crazy how one little setting can block your voice entirely.
RLXXI
3rd rock
Automotive Technician
I had the same problem and figured out that turning off Wi-Fi temporarily while on the call fixed the cutting out. It seems like the switch between data and Wi-Fi messes things up.
Turn off wifi calling.
