csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Good looking truck but I worry that you just killed your efficiency. Lifting the front end of any F150 can have a 10–20% range loss. Lifting my ICE dropped my mpg from 21->17.
Hopefully since the lightning is flat on the bottom it won't be that much but increasing the turbulence under the bottom greatly increases drag. Most of the guys that have leveled the front report a significant efficiency loss due to worse aerodynamics.
best of luck and let us know how it goes
jaimeoleal
At this point, doing this investment one should know.. and I knew.. you are right it takes a hit, Im cool with it though, love how it looks, I wanted to share for people that wanted to see how it looks, hope it helps somebody you know, thanks for the comment!
JRT
Huntsville, AL
Lightning
I think it is cool, but my range is never better then 2.1 m/kWh for an empty max of 275 miles ,but realistically I'm not going much past 200 miles. But if I'm not fast charging on road trips past 80, my range to 0 is 220 miles. I'm probably going to spend time to 90% from now on to be honest. What is your m/KWh now with these changes?
jaimeoleal
Your usage is very similar to mine.. I agree with you and right now I do 1.8kw/hr mostly but i have not done any longer than 50 miles distances yet, i want to test out on a scenario like that and check out what that looks like
N87
Leo
communic2
23 FL
Cool looking truck! Something I consider doing in the near future too.
Oneand0
Mario
South Lake Tahoe
Digital Investigator
Looks awesome!
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
Just wanted to share my setup on my new lightning, no rub whatsover or any other but but the leveling kit.
Has anyone tried if a 275/65 will fit without a level. I’d take the Rivian all terrain pirellis in a heart beat if I knew they fit.
jaimeoleal
I actually just ordered Nokian Outpost nAT which a lkot of rivians are praising above their stock pirellis, they are appearantly made for EVs, I will post some photos here once i switch, I did go with 35s on that too.
On your first question my brother has 275s/65 on his lightning withouth a level and they fit with no problem, thats for KO2s though.
Shawnson
Edmonton
Developer
Thanks!!
jaimeoleal
Update here to show the Nokians, they are supposed to be more EV oriented, they are a smoother ride and same noise level as ko2, testing the efficiency and will report back
Ford F-150 Lightning 2" inch Readylift kit with KO2 35x12.50 tires on factory 20" wheels - Lightning Lariat ER IMG_3716
Ford F-150 Lightning 2" inch Readylift kit with KO2 35x12.50 tires on factory 20" wheels - Lightning Lariat ER IMG_3718
huff92
chris
Washington
2025 F150 Lightning Lariat
Any update on the efficiency with the Nokians?
