Spare tire for 23 Platinum.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
What size spare came on the 23 Platinum with 22" wheels. Just found out I don't have one . Used from Dealer. Not cool.
Iroc34a
Iroc34a
Roc
Thanks. Crazy it doesn't have one at all. Dealer said it was traded in that way. Too far to drive to argue!
rdr854
Northern Virginia
I will look when I get home. The spare that came with my truck (Lariat) is in the garage as I replaced it with a full sized spare with matching wheel.
Iroc34a
Iroc34a
Roc
Thanks.
Costjim
US
Ford Lightning 2023
I took my spare off last night to check it. This is what it looks like.
Ford F-150 Lightning Spare tire for  23 Platinum. IMG_4401
Ford F-150 Lightning Spare tire for  23 Platinum. IMG_4400
Iroc34a
Iroc34a
Roc
I just got a 275/17 from a buddy's older F 150 ice. I think this would work in a pinch ! Seems strange to me since the L has independent axles that they wouldn't supply a spare of the same size.
My 2022 has a temp spare...
Iroc34a
Iroc34a
Roc
TomB985
Isanti, MN
2022 Lightning XLT ER
This is what comes to mind when I think of something that’s not a full-size spare.
Ford F-150 Lightning Spare tire for  23 Platinum. 1718595806278-1
The spare tire on our Lightnings is the strangest thing I’ve seen…a full-size truck tire that’s marked for temporary use only. It has much less tread and a strange tapered tread design, but it’s a far cry from the donut found in the truck of most cars and CUVs. I’d love to know how much cheaper this is than a regular tire in that size.
Ford F-150 Lightning Spare tire for  23 Platinum. 1718596013250-zn
Ford F-150 Lightning Spare tire for  23 Platinum. 1718596062209-tr
Iroc34a
Iroc34a
Roc
Very strange. All the fleet F 150 trucks we have at work, all 2020- 22 came with same size spare as on the Steele wheels . 17 inches.?
A 17" wheel won't fit over the rotors with the wrong offset. Better to check it before you rely on it.
Wheel size doesn't matter as long as the overall tire diameter is close.
Iroc34a
Iroc34a
Roc
According to this thread it is an 18" wheel on all Lightning trims (tire size not specified).
https://www.f150lightningforum.com/forum/threads/check-your-spare-tire-size.17690/
And this thread says its okay for them to be dissimilar.
https://www.f150lightningforum.com/forum/threads/spare-tire.18832/
But read the Owners Manual that is referenced.
Well there are a bunch of Spares off of wrecked ICE F 1
Thank you. I was just researching this. Going to have to find the correct size.
Muerg
Spruce Creek, Pennsylvania
engineering manager
All, I have both a 2017 XLT and the lightning. The 2017 has 17" steel wheels. they do not fit over my ligtning's front brake calipers. You might want to try that 17" spare before you need it. Might fit over the rear caliper, I didn't try, and you could do a rear to front swap of one of the standard wheel tire assemblies and put the 17" spare on the rear if you got a front flat. Not my idea of fun on a roadside.
