New truck one week. Frunk stopped opening to the full
Lightning143
Indianapolis
Ford f150 lightning flash
All of sudden today frunk stopped opening full, it opens about a foot and need to open the rest manually. Tried to set the height adjustment. I started reading threads and looks like No one is successful without going to the dealership.
Please if anyone had luck with any home troubleshoot, thank you in advance. One of the reason to switch to this truck is to avoid dealership hurdles, unfortunately it just took a week and now I'm searching dealerships and service reviews.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Search the forum for 24-2103. There is a service bulletin that might apply. There are a lot of frunk threads with different solutions.
Lightning143
Indianapolis
Bought at a dealership close to philly. Currently couple hundred miles away from philly.
AmandaB
US
2022 Ford Lightning Lariat ER - Red
Maineiac12
Iowa
I had the same problem and was able to fix it with FORScan. I reset the frunk module and then ran the self test procedure and that fixed it.
If you don’t have FORScan you can try manually raising the hood and then holding the frunk button for a few seconds until it beeps. That will sometimes reset the opening height.
BennyTheBeaver
Alternatively, open the frunk, disconnect the negative 12v terminal. Wait 10 seconds, reconnect negative terminal. Manually close frunk slowly, giving it a firm push right at the end to help it latch. Start your vehicle and open the frunk from inside the cab. See if that remedies your issues...
BarryGoyette
Barry
Photographer
Just had this done. Take to your dealer. They will do software updates and then re-initialize the frunk motor limits. In some cases they will replace the motors but this exact behavior is not uncommon and they should be able to do with the initialization procedure. For me, all the user hacks were a waste of time, so just take it in.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
