Is it typical for the underside of the hood to be not color matched?
pbgear
NJ
2022 Lightning Lariat
My truck is ice metallic blue, but the underside of the hood is painted white. I've never seen that before on any other vehicle I have owned.
Oh, and bluecruise 1.0 is getting old.
Dan C
Dan
2023 lightning lariat, 2022 Chevy bolt
Mine doesn't match, ICE trucks don't match either.
WhalerDon
Don
2023 Lightning Lariat ER and 2023 XLT SR
It is normal for the underside of the hood to not match. The paint is a three coat process. First a grey electrocoat then a primer and finally the top coat. The top coat is typically not sprayed onto all interior surfaces such as under the hood.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
It depends on the color it appears. My carbonized grey matches. Or maybe the carbonized grey is actually a primer with a clear coat?
Grease Lightning
Johnathan
Albany, Oregon USA
Mine matches. Carbonized Grey.
Adventureboy
My hood underside is black - the exterior is Antimatter Blue
WhalerDon
Don
Yes, they have 3 or 4 colors of primer and they use the one closest to the top coat. After 30 years of IT engineering in Ford assembly plants I am quite familiar with the process.
Grease Lightning
Johnathan
Albany, Oregon USA
Mine is not primer. It is the metallic flake style of paint.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Both my 2022 LER Ice Blue Silver & 2023 LER Silver are same corresponding color under the Frunk
Karlos
Karl
DFW & Kerrville Tx
Karlos
Karl
DFW & Kerrville Tx
