- First Name
- Brandon
- Jul 26, 2022
- Tucson, AZ
- 2022 Lightning ER, 2025 XC90 Recharge
I was referring to the onboard charger, not your EVSE. With that code, I don't think the onboard charger is the issue anymore. That duck is quacking like a bad battery module.I seen the Shifter issues some were having, and played with mine a little. I don't think it's that since it wont charge. I had someone on here run the VIN and its throwing P0B24:21 "EV Battery "A" Voltage Unstable: Signal Amplitude Less Than Minimum"
I do have another charger but haven't tried it. Been a little under the weather today, but I will try it later. I appreciate it the help.
I'd call the BEV hotline and start a case number before you take it in. Might help get things rolling quicker.
