Battery increase
earlyadopt
Woodstock
MachE, Lightning XLT
Insurance Broker
As most of us already know, the actual battery on board the F150 Lightning is larger than stated. Ford purposely understates since they are warrantying the battery for 8 yrs and they want to avoid users charging always to 100%. My question is the following. Now that the Silverodo is on the seen with a huge battery and range, will Ford release more range or be prey to the new range capablity of the Silverodo? I must admit that had I realized that the Work truck version was coming out, I would have waited to get the extra battery range. In Canada, the darn extended range battery on the Ford was $15,000 more to get it over the standard range. When comparing to the WT4 from GM Silverodo to the Ford Flash, there is a compelling argument to go with the Chevy Silverodo. So I am hoping that Ford gives more range like they did with the MachE extended range battery so to keep competitive.
Maybe I will not hold my breath, could be a long wait for this to happen.
Ford is being hammered with warranty costs right now. I doubt they open themselves to to more potential liability.
earlyadopt
Woodstock
Insurance Broker
Good point. A lack of sales could also hit the bottom line if range becomes an issue as it will next year. When all things are equal with pricing, than range becomes more important
Athrun88
Toronto, Ontario, Canada
Wishful thinking, but I'm waiting for some battery startup to make higher capacity/density battery packs for BEVs. With 'Right to Repair' gaining traction, something like an aftermarket battery swap in the future might be a possibility!
SpaceEVDriver
Arizona
Not likely.
All of the dealers I contacted told me that the Work Truck was only available as a Fleet sale, so the pricing comparison is a little less obvious than it appears. We considered waiting for a Silverado, but the costs were/are much higher for the Silverado. And in the end, we found a great deal ($67k OTD for a Lariat ER fully loaded, etc.).
earlyadopt
Woodstock
Insurance Broker
Not likely.
Pricing in Canada is not so wide apart. If I compare a Flash to the WT4, pricing is much closer but range with the Silverodo is better. Once discounts come in, it will be interesting.
There is not much buffer on the top. Module voltage at 100% SOC is 4.09v. Nominally max voltage for a NMC pack is 4.2. In the real world that's maybe 20 miles added range, at the expense of chopping battery lifespan in half.
The Weatherman
Dean
South Central KY
Jim has been preaching recall/warranty costs for more than two years. And it just keeps getting worse and worse. Wonder what his Golden Parachute looks like? ?
ALAN BORER
ALAN
PALM COAST FLORIDA
2023 LIGHTNING LARIET , 2023 POLARIS SLINGSHOT , 2000 HONDA VALKYRIE
RETIRED
What about a battery extender for the bed of the truck like the Cybertruck ?
Evlar77
Evan
Port St. Lucie, FL
2024 Ford Lightning Flash
So, in terms of numbers... Our ERs are 131kwh usable, like 141kwh total capacity, correct?
SpaceEVDriver
Arizona
143 kWh total, probably rated at a 1C discharge rate.
Updated with photo. Please excuse the mud--this is a work truck.
Ford F-150 Lightning Battery increase PXL_20241031_224646678
