Dreaded camera fault
awilli1010
SE Michigan
I took my 22 lariat er in today for the front parking sensor and frunk csp’s. I now have the small 360 camera issue. The service manager informed me that they can’t get the camera back to its original size even after loading the apim and doing step 11. He took me into the service area and the tech showed that me it wouldn’t take. It was throwing a “configuration not applicable to this vehicle” fault. They escalated the problem to a field service tech. Has anyone seen this before? Tia!
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Jasin
Jasin
2022 Lightning ER Lariat
I am having the same issue
Jasin
Jasin
Ford I am having the same issue after the dealership could not do it i am now trying with FDRS myself
Ford F-150 Lightning Dreaded camera fault 20241213_155741
Ford F-150 Lightning Dreaded camera fault 20241213_153209
Ford F-150 Lightning Dreaded camera fault 20241213_153826
awilli1010
awilli1010
SE Michigan
That’s the same as mine! Exactly!
Jasin
Jasin
awilli1010
awilli1010
SE Michigan
Let me know if you hear back from Ford
the people on here are currently in contact with me. I hope they can help.
Jasin
Jasin
I am about to do the FORScan fix if I don't find a solution
awilli1010
awilli1010
SE Michigan
it’s an issue with the 22 model is what my dealer said.
awilli1010
awilli1010
SE Michigan
please post your progress. My dealer was clueless.
Jasin
Jasin
I did the FORScan fix for mine, still have to use the menu to pick which camera but at least it's back to the full size.
awilli1010
awilli1010
SE Michigan
mine is back in the shop with some engineering guy looking at it. They’re trying to tell me its way it’s supposed to be. I guess I’m going to have to complain some more. Forscan didn’t fix mine.
Tell them to show you any lightning they have on the lot with the same thing. Good grief...
