Farmford42
WA
69 Bronco
Farmer
I’m still trying to sort out the camera fix. Had the update. Remote tech came out and when I looked over his shoulder it said the parking sensor update had not been applied.
Mike G
Mike G
N. AL, USA
What were you looking at? Was it PTS? Or something in FDRS?
If it was the PTS screen that shows the open FSAs for your VIN with yellow highlighting behind the text...then yeah, that will still be on the PTS screen until they process the action in the dealership showing it's completed. It's not an immediate thing in most cases.
Here's an example of the PTS FSA block:
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks Outstanding_FSA
But again, I don't know what you were looking at.....
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I’ve had such unfortunate luck overall when taking trucks in, to the point that this entire past year on my lightning I’ve avoided the shop completely so far. I am encouraged enough after reading others experiences overall with Ford Mobile service that I’m going try that out….
I’m showing that I’m still due still for both of these CSPs:
——> 23B70
——> 23B56
Pitbull2o08
Ohio
I just did this, took 5 hours or so just for this update. One of my TPS sensors didn’t work and needed reconfigured.
On the app, it didnt clear this CSP. So I don’t know if it was actually done or not.
Mike G
Mike G
N. AL, USA
Clearing the FSA on the FordPass app or on PTS is a function of the shop signing off the repair as completed in the system. Many shops don't get around to doing that 'cleanup' administrative stuff until days or sometimes weeks later. I wouldn't worry about.
I do my own updates. So my outstanding FSAs for those issues stayed in the system for many months after I did the updates, until I asked my service advisor to sign them off when I went in for the 10K (AKA a tire rotation). It means nothing to see those FSAs still showing up if you know the work has been done and there aren't any issues.
I checked the lane centering setting and it was already set to "off", so, hmmm... oh well, hitting the steering wheel button each time I turn on cruise ctl. is no big deal.
@LUXMAN - Good luck - hope it does fine for you!
There was an update, maybe silent, that changed this. It is well documented in another thread. Turning on cruise control turns on lane centering regardless of the lane centering toggle in Sync.
I too miss having that be an option. Have to turn it off on the steering wheel each time.
Pitbull2o08
Ohio
How would I know the work was done?
Mike G
Mike G
N. AL, USA
I noticed something today that I've seen before but since I don't often drive when it's dark, I'd forgotten about it. Anyway....I started the truck this afternoon and the IPC brightness setting popped up in the middle of the display, indicating it was full bright. So I reached down and bumped it down about three notches.
But then it occurred to me that I'd had to do the same thing two days ago when I had to leave the house very early for an appointment (still dark).
Which then reminded me about the fact that the 12/24hr clock setting is stored in the IPC (but set using the toggle in the Sync menu..?)...and everytime I'd change it from the 12hr back to the 24hr format I like, the next time I'd start the truck it would be back to 12hr format again. Well, I did fix that using FORSCAN after I got fed up with it changing all the time, and after setting the bit to make it 24hrs, that seems to have stuck.
I wonder about the IPC brightness setting though. I'll bet if I went back out there right now it would be back to full bright again. Wonder why these settings in the IPC aren't persistent across key cycles?
Mike G
Mike G
N. AL, USA
LUXMAN
F150 Lightning PRO and XLT
Pilot
They said it did but only took about 10 minutes for that one.
Just found a problem. One of the updates re started the door chime and chime at start up as well as messed up my bed light activation via the switch I installed. I need @GDN to help me correct those. My Matrix headlights, 5 click turn signal and zone lighting are still good though
And I found the splash screen when I open the door is gone.
I was going to call the dealer but then thought about a hard reset yesterday. I unhooked the negative battery terminal for anout an hour and a half (had to run errands) and VOILA! , All back to normal.
Nothing solves more of this trucks problems than a 10 mm wrench.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I've had that happen too. I've also had the headlights turn themselves from auto to on. I read that there was a bad batch of headlight switches that causes that. I suspect the brightness thing is related since it's the same switch module. Dealer will replace under warranty.
CRAIGC540
Craig
Moreno valley
Technician
This changed for me after a dealer update, I know have to turn it off when cruise is turned on. I'd rather turn it on when needed.
CRAIGC540
Craig
Moreno valley
Technician
I had Ford home service pick up my lightning to apply the front sensor, frunk and the charge port recall. I told them maybe not do the front sensor because I was worried about having problems. He was fully aware of the long update and needing to have a battery tender for the 12 volt, so I told him to get all recalls done. They went well except he brought it back with the small 360 screen and no beeps when the camera pops up to see close objects., this after telling him to ask the tech to recalibrate the camera. To his credit he did tell both the tech and the porter to check for that problem and still didn't get done. They picked it up the next day and corrected the camera. Home service is the best and my dealer Raceway Ford seems to have a really good EV tech. Funny thing is I wasn't ever going to go to them for service because they were my original reservation dealer and found out I would be charged a markup so I changed to another dealer 29 miles away. I did try their service and didn't like it so decided to try Raceway Ford and have had nothing but great service. I ask Raceway to update my sync to 10.1 but since I wasn't having any problems the would charge $210 so I decided to wait for the OTA.
LUXMAN
Pilot
I agree. Now I have this on my pro and it’s annoying. I never use Lane centering unless I’m on a long trip.
