Dealer cannot install Trailer Brake Controller on 2024 PRO Standard Range
FoxRidgeFarm
Gordy
Ford F150 Lightning Pro
Farmer
ML3Z19H332AB
This is the kit part number.
I have the part Kit and everything I need. Let me know your schedule for beginning Monday the 13th going forward, as I should have some time to walk through it with you.
Thank you for your great support!
The farmer
Jesse-Infotainment
2024 F150 Lightning Platinum
The farmer
Ok. Just reach out when you are ready.
PrimeRisk
Denver-Metro
Technonerd
Ok, now I'm just confused. I actually pulled what has been described as a "Blank-Box" from my '24 Lariat, and it certainly does NOT appear to be a blank box. It has electronics in it. So, is this possibly the case that they put the controller in the truck, but just failed to put in the dash switch?
If all I need is the dash switch (ML3Z-14529-AC) which is oddly listed as compatible with the lightning, I'll be super happy about this.
I pulled this out of my truck this afternoon:
Ford F-150 Lightning Dealer cannot install Trailer Brake Controller on 2024 PRO Standard Range 1736634163557-p7
This is the part pictured on the part.ford.com site that pictures the exact same part number on it (assuming that ML3T-19J295-GA is the part number):
Ford F-150 Lightning Dealer cannot install Trailer Brake Controller on 2024 PRO Standard Range 1736634282713-o9
Or is there something else going on like if I order the ML3Z-19H332-AB kit, the physical module is the same, but it's programmed differently?
