I have VIN and Scheduled Build for 2025 Flash for Canada
rparry
Bob
F150 Lightning Flash Ordered Nov. 18th 2024
I just stopped by my local dealer here in Chilliwack and my 2025 Lightning Flash is scheduled for the
week of Jan. 20th. The feeling is that delivery will be late February but will update when I know more.
Bob
Calvin H-C
Calvin
Either that is the optimistic point of view or Ford's getting more efficient at what they do between building and delivering.
My wife's 23 Lariat had a blend date of January 22, 2023 but it wasn't delivered until the end of May, and Toronto is somewhat closer to Michigan than Chilliwack is. ?
Would you mind sharing the top /right margin of your window sticker?
ex.
Ford F-150 Lightning I have VIN and Scheduled Build for 2025 Flash for Canada 1737213632884-52
I'm curious what the planned production counts are for next week.
Does your truck have factory spray in bed liner on the build?
Winter/Spring 2023 was a horrible period with production stalls for various reasons.
Ford F-150 Lightning I have VIN and Scheduled Build for 2025 Flash for Canada 1737213864346-0r
Calvin H-C
Calvin
True. The zero production February was due to the battery fire in their lot - probably when my wife's Lightning was there
rparry
rparry
Bob
ex.
I do not have the window sticker as of yet. I passed on the spray in bed liner. Looking into aftermarket options when the truck arrives.
rparry
rparry
Bob
I am hoping for something better than that. The plan is to start my Coast to Coast Bucket List trip around then. I have a number of things planned to add to the truck for this trip.
The actual departure date depends on if the Canucks are still playing in late May, something that is looking less and less likely at the moment.
Keep updating as I know more.
Bob
rparry
rparry
Bob
The reason I asked about spray in liner, as it has a effect on the values.
Your truck is 162nd of 267 to be built that week, that's pretty low volume based on prior history, but it's a start!! Good luck
Lucky Larry
Calgary, AB, Canada
23 Lightning Platinum, 25 Mach-E, 17 RX 350, 06 Pontiac Solstice
If you have the order number and the vin number you can track your trucks status on ford.ca using the link called "Vehicle Order Tracking" at the bottom of the page, it located under the "Shop" heading.
The order number is a 4 digit code that usually has 1 letter. If you were able to get the a copy of the window sticker, you can find the order number below the final assembly plant location in the item # box. For example you will see a something like this A6-P654 QT/2. The order number for this vehicle is P654.
I have attached a vehicle order tracking status screen shot for a flash that is scheduled to be built during the week, January 20 2025.
Ford F-150 Lightning I have VIN and Scheduled Build for 2025 Flash for Canada Screenshot_20-1-2025_185735_www.ford.ca
Track production progression here Ford-CA or here Ford-US
When the truck goes live you will see it here with all the modules fully coded: Ford-Service-Info
rparry
rparry
Bob
I used that link and plugged in the info. I got a lot of BCE Module information, have no idea what it means though.
Bob
rparry
rparry
Bob
When I looked at Model Information on my truck I see this:
  • 4 WHL L/H PART TIME DRIVE
This says it is Part Time 4 wheel drive. They did not change this for 2025 did they? Or is this just standard printout for F150's?
Bob
