Door keypad programming
No door card and only one fob? I would contact whatever company is handling your lease. At least with the fob. If they expect 2, which the truck should have come with, when you turn it back in, your looking at hundreds to replace it.
dkuhlman99
2024 F150 Lightning
Yeah, I contacted the leasing company and they said I would need to get a second FOB from a dealership. Went to my local Ford dealer and they said it was a two hour process and $500.
No thanks. Just trying to get a work around for the keypad programming. Right now my keypad is useless without the factory code.
Fact - it's less than a 15 minute process. FOB cost from Ford isn't cheap, but that dealer is taking advantage of you. The FOB is likely over $200 as listed on the Ford parts site, which is why people buy 3rd party fobs.
That dealership is charging more than most.
mr.Magoo
2022 Lariat ER, AMB
Thanks all for your input.
My 2024 Flash didn’t have a plastic card with the code, so I’m hoping to locate it in the passenger side foot well. Will update.
It is, or st least was on my 22
Ford stopped providing keypad code cards for 2024. You have to use the method above with two fobs:
SSM 52310 2024 Nautilus/F-150 - Keyless Entry Keypad Code Card Missing
Some 2024 Nautilus and F-150 vehicles may incorrectly list the keyless entry keypad code card on
the loose item checklist. 2024 Nautilus and F-150 vehicles in North America do not include keyless entry keypad code cards. Clients are now able to retrieve the vehicle's keyless entry keypad master access code in vehicle by following the instructions in the master access code card (available only on F-150) or in the Owner’s Manual > Keyless Entry Master Access Code. This process requires the use of two programmed intelligent access keys.
Bet it is still printed in multiple places on the vehicle.
Yeah, this was to address the multiple folks who keep saying their 2022 came with a card.
Things change.
PJnc284
Garner, NC
Fun fact, if you happen to have two fobs, the OEM door code shows up after the second fob during the programming process. Doesn't help the OP though since he only has 1.
Yes, that was stated in post #7
dkuhlman99
2024 F150 Lightning
Leased a 2024 F150 Flash and only received one key fob. Trying to program my door entry keypad the truck requires two fobs. I didn’t lease from Ford so it’s a pain to get another fob.
My question: is there a way to display or locate the factory keypad code?
Update:
Was able to locate the door lock pad code behind the small removable panel in passenger foot well. That panel just pulls open and I used a small endoscope camera to see the code. Thanks to all for the help.
salengueros
salen
San Francisco
Honda
I’ve had a couple of late‑night lock mishaps, and the crew at https://royallocksmithfl.com/ saved me more than once with quick, upfront help. Their techs actually show up fast and don’t play games with extra fees. If you need anything from rekeys to car key programming, they’re easy to work with and you can grab a free estimate before committing.
I’d check the wallet card in the owner’s packet first. If it’s missing, a dealer can pull the factory code from the truck’s module with their tool, even with one fob.
Thread is a year old.
Code is on module in right footwell.
