Battery Charge - Charge Capacity v. Percentage Charged
NeuroDawg
Puget Sound, WA
'24 Flash ER (previously '23 XLT ER)
I recently purchased a new '24 Flash, after my '23 XLT ER was returned to Ford via buyback. I never had any issue like this with the XLT, and I'm trying to figure out why I'm seeing what I'm seeing.
I consistently charge to 90%. On my XLT this would reliably give me a charge of 115-118KWh (displayed through Car Scanner Pro). On a road trip I took in October, the two times I charged to 100%, gave me 127.4KWh and 130.66KWh, exactly what I would expect.
However, with my Flash, I charge to 90% and I'm seeing capacity of ~105KWh. This morning when I went to work the display in the car said 90% charged, car scanner pro showed HVB SOC Display to be 89.5%, and battery charge of 104.75KWh.
This has me concerned. 104.75KWh should display ~80% charge, not 90%.
Can anyone explain this to me? Is it temperature related? It's been the same with overnight lows in the high 20s to mid 40s. Is it something else I haven't thought about? Is it a matter of a module reset, or disconnecting the 12v for a while to allow a complete system reset?
I currently have my truck plugged in and am charging to 100% to see what I get. I'll report back. For what it's worth, this truck has a build date of 3/24 and I bought Jan 30, so it sat on the lot for a few months. Also, my 12v consistently reads low, 75-80%. I've been able to get it to 92% after leaving it on a trickle charger overnight, but then it drops to the 70s-80s. I have an appointment with service in a couple weeks to get that checked/replaced.
mrtyndall
matt
24 Flash
I have a similar issue with my flash, at least with range. I need to check the battery tonight when it charges up and see how many KwH I have
NeuroDawg
Puget Sound, WA
I purposely left the GOM range out of my post because of how it fluctuates with temperature and driving style. This is all about the battery capacity and charging percentage reported by the truck.
NeuroDawg
Puget Sound, WA
Leave the truck plugged in but turn it on (run). Iirc it should then warm the battery to 60f. I expect with the higher battery temp you will see a higher capacity.
Probably. Does that mean that the percent charged display changes because the truck says to itself "in this condition I can only fill the battery to 118KWh, and 90% of that is 105KWh"?
I guess that I expect percent charged to represent a percent of the 131KWh battery capacity.
But... I can see why it might do it the other way. Otherwise in the cold temps when the battery only gets to 115KWh and says 87% charged, everyone would be saying "Why doesn't my truck charge to 100% when it's cold?"
You need to charge to 100%, and leave it sit on the charger, as the cells balance. See what the reading is when the battery is nice and warm. Then, if it's still low, you need to run it down to 10 - 20%, and charge it back to 100% again, and then look.
As stated, temp affects energy. On a recent trip out west in the bitter cold, here are two readings of the same kWh. Note the temperature and state of charge differences:
Battery Temp SOC% kWh
89.6 85% 114.21
46.0 93% 114.20
At 90 degrees, 114.2kWh was displayed at 85% SOC. At 46 degrees, the same energy was displayed at 93% SOC.
Billybender32
Spokane
For lightning 2024
I've had the exact same issue that you are concerned about. It doesn't seem to be affected by temperature either for me charging in my garage, but when I charge to 90% I too only get about 104 to 109 kilowatt hours. When I charge to 100% at home I will get somewhere around 124 KW. I did get 127 once but it's usually lower. It seems like the battery capacity is slightly lower than promised or the battery management system is unreliable. I've driven it all the way down to 0%. Recharged backup to 100% a couple times and this has never affected the amount of capacity I get when I charge it back up to 90%
If you find a solution, please post and let us know
flyct
Jerry
South Florida
Blissfully Retired
..........................When I charge to 100% at home I will get somewhere around 124 KW. I did get 127 once but it's usually lower. It seems like the battery capacity is slightly lower than promised or the battery management system is unreliable...............................
I seem to remember reading that the 2024 models may now only have 124 kWhs usable vs the 131 kWhs on the previous year trucks.
Someone correct me if I am wrong.
Billybender32
Spokane
For lightning 2024
If you look under your truck at the battery there's a sticker. If remember mine is 143 KWh battery So should have usable 131 kwh And it's a 2024 so I don't think that's the case.
