BlueCruise No Longer Showing Lane Change Visual?
ziptbm
'22 MME GT & '22 F150 Lightning Lariat ER
I *believe* I am on BC 1.3 (not sure how to confirm if my vehicle received anything newer since I last did FDRS updates in Aug 2024) and noticed today that when I change lanes in my 22 Lariat, it no longer shows the visual of the Lange change on the driver screen. The lane changes without issue, but it no longer shows the arrows and path to switch lanes.
It still does in my 22 MME, so could there have been an update that removed this feature? Or is there an option I’ve overlooked?
You might have had another update come in that conflicts with your updates. I would try your updates again if it persists. It could just be temporary while your system is being updated also.
Mike G
N. AL, USA
It never showed on the lightning afaik. Or at least never did for me after manually updating.
I was gonna say, but you beat me to it...mine has never had the animated lane change graphic like my Mach-E has.
Does anybody actually have that?
ziptbm
hmm…maybe I was imagining it.
Thanks. For the confirmation!
The only place I've seen the lane change graphic is on the driver assist screen on the IP. No other screens have any lane change indications.
Deleted member 20120
Guest
Mine shows the animation
PJnc284
Garner, NC
you have a 24. Ford probably updated the ipc for those from the factory. Seem to recall seeing that the animations weren't included for those that officially received 1.4 end of last year either.
Guest
Sounds like something ford would do lol
Guest
What screen do you see this on. I have a 24 lariat and don’t recall seeing an animation when changing lanes.
Bottom right hand corner it shows an animation. When I go home tonight I’ll take a video
