Washer FluidThat reminds me, I have to maintain my brakes! Someone suggested this monthly.
Put it in N and stop with the brakes. Scrapes all the potato bugs off the rotors that I never use.
So much maintenance to remember! ?
Apparently the Phone APP checks that for me nowWasher Fluid
Remember to check Washer Fluid.
That's about it.
Might be good to give the truck a nice 'cold reboot', if you will. Disconnect the 12v battery for 20 minutes or so, then reconnect it. I've started to do this quarterly (coming up soon).
*****************UPDATE***********I've had my "24 Flash for less than 2 months now. So far... my favorite vehicle I have owned. On Friday, the yellow wrench symbol appeared on my dash followed by a message that read," powertrain malfunction/reduced power- A powertrain or 4-wheel drive fault has been detected." I tried to make an appointment at my local dealer but can't get it in until next week. Today, I started it up and the wrench symbol and messages were gone. My question is: do the warnings, cautions and symbols go away after cycling the ignition on and off so many times? BTW the truck runs great, nothing appears to be wrong with it.
Thanks
Tino
This sounds better than a bad battery module. But there’s a whole other discussion about the GSM ( gear shift module?) that’s been popular this week too.*****************UPDATE***********
Finally got to the dealer. Problem is related to a fault with the gear shifter. Apparently, this a common problem with all ford trucks, not just the Lightning. The dealer said they would overnight the part and try to install tomorrow or Wednesday. About 3 weeks ago I couldn't shift from park to drive, I turned the truck off and on and was able to drive away. It only happened once. Apparently, there is a Technical Service bulletin about this problem.
LATEST UPDATE******* Gear Shift Module replaced today. Took dealer about an hour and a half.Is the gear shift module issue specific to model year - if so which years?
I saw this TSB for 2021 F-150 ICE
TSB 21-2141
Yes, I used an OBDII scanner and the Forscan app on an Iphone to get the screenshot of the P0929 Gear Shift error.Did you use carscanner to get the error code? At least the error code is very descriptive.
