21st Century Truck
Martin
I think this is the case. So I had help from @21st Century Truck in activating this mod, and the sound was instantly better. While I don’t have the color wheel, if I turn the volume up to about 11 and press the Beosonic button, I can definitely tell that there are preset changes to the equalizers - some highlight background vocals, some focus on the music, and some change the speaker focus. Not that I have the best ears, but as far as I can tell, there are 4-5 different presets pressing that button. The one thing I did notice is that each time I start the vehicle, I have to go press the Beosonic button to “activate” it. It’s very hard to tell on XM music because of the compression, but on downloaded “hifi” Spotify songs, the quality difference to me is noticeable.
This is all anecdotal of course. I could just be hearing what I want to hear.
As it happens, I helped a friend last week adjust his 2023.5 Mach E Premium system to include Beosonic.
At 1st we both heard some slight changes while sitting in his garage. However, after my friend drove the car for several days, he definitely heard the Beosonic changes and loves them. It took him multiple drives, experimenting with different rock and classical music tracks, to grow to recognize the Beosonic's presence.
Unlike the Lightning, the Mach E had a notable electronic systems evolution between the 2023 models and the 2023.5 models. So, as an example, I am pretty sure I wouldn't have heard any Beosonic difference on my now-gone 2022 Premium tech package Mach E.
Gerstein1989
Alexander
Barrie, Ontario
2024 Lightning Lariat
Plumber
There were issues when the 2024's first came out (example), but Forscan ultimately released newer versions of their software. Just reading back through this thread you will see lots of success with 2024's.
I have a 24’ and it works great. What’s crazy about glare free you don’t even notice the high beams turning on. I think they gradually turn on as when I was testing them I didn’t even realize they were on and then I pushed the stock and low beams turned on. The technology on the headlights are pretty cool.
Al-Taie
Firas
2023 F150 Lightning 511a lariat
This is a new version of the original FORScan thread. It contains historic information but its mods may be out of date.
FORScan allows you to make modifications to certain module settings that change how they operate. The source of many mods is from FORScan guru @Livnitup. He has maintained spreadsheets with module information. You can find them on this thread.
Post #2 gives links to equipment, tutorials, etc. Please read it before doing anything for the first time. And make sure you backup your current settings or write them down before making any changes!
In the settings that follow, “x” means leave the value as is and “-“ is the checksum value that FORScan will re-calculate for you when you write the data. An " * " means the new value depends on the old value so read the notes. While all the settings can be done using As-Built Mode, some can be done with “Easy” mode. Both are shown where applicable.
Global window open/close using keyfob: only works on the front windows because one-touch is not enabled in the back windows.
DDM 740-06-02 xxxx xxxx 01--
PDM 741-06-02 xxxx xxxx 01--
DDM 740-06-03 01xx xxxx xx--
PDM 741-06-03 01xx xxxx xx--
BCM 726-11-02 xx01 xx01 xx--
BCM 726-22-01 xxxx xxxx 01--
BCM 726-22-02 xxxx xxxx 01--
APIM 7D0-09-01 xxxx xExx xx—
Or Use Easy Mode from this post
Glare-free headlights: enhances Auto High Beam behavior to provide localized dimming of brights based on surrounding traffic (pic): Dynamic bending lights continue to work. May take a couple of restarts to take effect. Settings were adapted from this F150gen14 ICE forum thread but HCM settings modified for Lightnings by @FlasherZ in this post. He notes to check there aren't any checksum DTC's set for the HCM. May already be enabled on certain Canadian vehicles.
APIM 7D0-09-01 x1xx xxxx xx--
APIM 7D0-09-03 xxCx xxxx xx--
IPMA 706-01-01 xxxx xxx9 xx--
SCCM 724-04-01 xxx4 xxxx xx--
IPC 720-01-01 xx8x xxxx xx--
IPC 720-10-01 xxxx xxx3 xx--
HCM 734-01-02 xxxx x2xx xx-
HCM 734-03-02 xxxx xxx1 x1--
HCM 734-11-01
0735 89
Enable Silent Mode
(AKA campground / dark mode)
Creates a SYNC toggle to turn on/off Silent Mode. Silent Mode turns off cluster lighting, welcome lighting, courtesy lights, and SYNC screen when opening doors; also silences the horn when locking doors. See this post for more info, pics, and how to enable using easy mode.
BCM 726-25-02 0101 0101 01--
BCM 726-28-02 01xx xxxx xx--
APIM 7D0-09-02 *xxx xxxx xx--
if C, change to D. If E, change to F.
Disable double honk with exit of running vehicle:
There is a Sync
setting for this this (Key Detection Alert). FORScan not needed.
BCM 726-63-02 xxx0 xxxx xx--
Lincoln Folding Mirrors Setting (still folds when locked; but unfolds when driver door closes instead of unlocked):
DDM 740-03-16 xxxx xxxx 01--
PDM 741-03-16 xxxx xxxx 01--
Note: has issue that puddle lights get disabled.
Remove "Full view not available" message on reverse camera screen while in motion (source)
APIM 7D0-02-02 xxx* xxxx xx-- If 0 change to 1, if 2 change to 3, if 4 change to 5, if 6 change to 7.
Note: reset APIM after the change. See this post for how to reset a module.
Enable cameras at speed - if you have lost the ability to see the bed camera while driving, try doing the Remove "Full view not available" message mod above.
Trailer Side View - 2022-2023 only. Standard on 2024+. Shows corresponding camera view alongside of vehicle when turn signal is applied with trailer connected. See here for how to fake a trailer. Note: requires newest 12/23 IPMA update.
IPMA 706-01-02 *xxx xxxx xx-- if 0 change to 3, if 7 then no change (2024's)
APIM 7D0-02-03 xxxx x*xx xx-- if 0 change to 8, if 4 change to C, adds Trailer Side View toggle under Driver Assistance
Enable 50/50 view in camera menu - 2022-2023 only, standard on 2024+ (source). Add a button to the Sync camera selection screen that shows a 50/50 view of the two side cameras (pics). Thanks to @PJnc284.
APIM 7D0-01-01 xxxx *xxx xx-- if 1 change to 3
APIM 7D0-01-04 xxxx xxxx x*-- if 0 change to 1, if 8 change to 9
Analysis to get these change here.
Fix front camera not popping up on screen when front sensor activated (source)
IPMA: 706-16-01 xxx*-xxxx-xxxx
if old value 0-7 then add 8 (hex) to get new value. For example 3=>B. If current value is 8-F, then this is not for you. Applicable to trucks without Park Assist and BC.
Fix Small 360 degree camera view – issue with some 2022 models after IPMA update
APIM 7D0-01-04 xxxx xxx* xx-- change from 2 to 3
Disable Seat Belt chime on vehicle startup. The truck will chime 4 times if you press Start with the seat belt disconnected. This is the US seat belt strategy. You can change to the European seat belt strategy which waits until the vehicle is in motion to chime.
IPC 720-01-02 xxxx x2--
Disable Door Ajar Chime
24-Hour Clock Persistence
(may fix issue on some trucks where 24-hour clock is not persistent)
IPC 720-01-02 xx*x xx--
0 12-hour clock, Chime disabled
2 12-hour clock, Chime enabled (default)
4 24-hour clock, Chime disabled
6 24-hour clock, Chime enabled
Disable Seat Belt Reminder:
IPC 720-01-01 xxxx xx0x xx--
This can also be done on a per-seat basis via instructions in Owner’s Manual (link)
Change Number of Blinks for Turn Signal Tap (original post)
Confirm your current value matches the 3 blink Default value below before changing.
SCCM 724-01-01 xxxx **xx xx--
Number of blinksHeated Steering WheelNo Heated Steering Wheel
3 (default)​
8C​
0C​
4​
90​
10​
5​
94​
14​
6​
98​
18​
It's might be better for this one to use Easy mode for the SCCM.
Auto Relock - if you hit the unlock button on the fob and do not open a door within the timer it will re-lock the truck. Adds Relock toggle to Lock Settings. See this post by @mrau for more info, pics.
BCM 726-20-01 x1x1 x1x1 x1-- old value should be all 0's
BCM 726-27-01 xxxx xxxx x1-- change 0 to 1
BCM 726-58-02 xxx* xxxx xx-- use this on 2021-23 duration: 1=30 seconds, 2=45 secs
BCM 726-58-02 x*xx xxxx xx-- use this on 2024 duration: 1=30 seconds, 2=45 secs
APIM 7D0-09-01 xx3x xxxx xx-- change 1 to 3
Walk-away Lock (WAL)
– 2022-2023 only, standard on 2024+
Note: this only enables toggles on the Sync Screen for toggling WAL and WAL Feedback (horn honk). To get the actual functionality you need the BCM updated from the dealer. See this post.
APIM 7D0-09-05 xxxx Cxxx xx--
Or APIM Easy Mode: enable Walk Away Lock and Walk Away Lock Feedback
Change Tire Size for Speedometer Calibration
Use BdyCM easy mode. Setting is Tire Circumference (mm). Also see these two posts: Easy Method (video), As-Built method (use addresses 726-15-01 and 726-15-02). Also possible DTC.
Heated Steering Wheel Temperature Setpoint (source)
SCCM 724-06-01 Bxxx xxxx xx-- default 35°C
0=24°C 1=25°C 2=26°C 3=27°C 4=28°C 5=29°C 6=30°C 7=31°C
8=32°C 9=33°C A=34°C B=35°C C=36°C D=37°C E=38°C F=39°C
Prevent headlamp switch from defaulting to Auto position - headlamp switch will revert to last position used on next startup.
BCM 726-74-01 xxx* xxxx xx-- change 0 to 1
Disable Vehicle Power Down Timer at Start - Whenever you start your truck, the Vehicle Power Down Timer is always enabled. This shuts the truck off after 30 minutes. This mod defaults the timer to off at start. See this post for details, warnings and source.
IPC 720-01-01 x*xx xxxx xx if F then change to 7, if C change to 4.
Note that 2022-2024 Lightnings with ACC will have a "F" and trucks without ACC will have a "C". As always, let me know if you see something different.
DRL Brightness Adjustment (original post) (not recommended)
This setting affects the DRL which is the lamp between the top and bottom headlamps (pic). It is not the light bar which is on XLT and above. Careful - you may get flashed by oncoming drivers if turned up too bright.
BCM 726-42-01 x2x2 xxxx xx--
BCM 726-38-01 xxxx 64xx xx--
example values are 64 =100%, 4B =75%, 32 = 50%, 19 = 25%, 0A =10% (default).
I need help with the options on the forscan spreadsheet if there is any way to understand the full name options for example FESOV interested body control module C, I'm trying fix my truck affter I corrupt the as bulit file
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 20250421_234110
FEVSOV=front evaporator shutoff valve.
I figured that out by Googling "Ford fesov."
You might get further by comparing your as-built to one that isn't corrupted. What exactly did you do to screw it up?
If you haven’t run FDRS or taken it to the dealer (who ran FDRS) or received an OTA, there is a very good chance the AsBuilt stored online is still good, i.e., pre-screw-up (link).
If not, let me know what options you have (particularly MaxTow) and I can send you the AsBuilt of a similar truck.
If you haven’t run FDRS or taken it to the dealer (who ran FDRS) there is a very good chance the AsBuilt stored online is still good, i.e., pre-screw-up (link).
Lol...this is a much better way to do it when compared to deciphering code gibberish.
I've made a couple changes to my wife's Navigator using Forscan but the Lincoln community is about as interesting in working on their own vehicles as you would expect them to be.? Anyway, at one point I decided I wanted to attempt to activate glare-free headlights. After a couple hours cross-referencing @Livnitup's spreadsheet and not getting very far I decided that giving up was the best use of my time considering I don't even know if the hardware is installed and my wife doesn't care.?
There are a couple tools online that let you compare files, highlighting the exact differences between them. If your motorcraft as-built files are the originals it should highlight the exact changes you made and thus how to fix them.
The Expedition and Navigators are different. I have tried to get lane change etc to work on them with no success. Side-loaded BAE from a 2024 Navi to a 2022, tried side-loading the BBC IPMA software from our trucks onto one, too.....failure. One guy even swapped an entire IPMA from a 2024 onto his truck and we still could not get it to work. The most successful attempt was the 2022 Navi we side-loaded the BAE software on. In his case, we got lane change to work even though the toggle on the touchscreen was grayed out indicating it was not working, but no luck getting in lane repositioning or predictive speed to work. I suspect the software int he GWM is not set up to support it which is what is making it impossible to figure out. The same may apply to glare-free lighting and other things we can do on our trucks.
Al-Taie
Firas
No my friend it is corrupt this is my truck bult
2023 f150 511A ER with Max trailer tow package.
275/60R-20
onboard scale and advance security package removed
My Kids accidently delated my backup last year i tried to recover it but it is in json file
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231444
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231526
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231632
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231650
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231729
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231745
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231709
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 Screenshot 2025-04-22 231606
Al-Taie
Firas
[/QUOTE
Thank you:)
Sorry to hear that. I'll DM you some matches.
275/60R-20
I noticed you're using a Mongoose. Wouldn't it be easier to fire up FDRS and write the config to the affected modules directly from Ford?
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
So my truck has been at the dealer for three full days to try to fix the Apple play issue that I’ve been having as well as trying to fix the fact that I have not had an OTA since October. I’ve had it in there twice and they have told me they have updated the modules each time. They finally called me and told me that it’s taken three days because they had to work with the mothership.
I was wondering if anybody out there could check to see if I have all the updates if I provide my VIN I don’t have that ability and would like to know before I head to the dealer to get my truck. I would really appreciate any help anybody could give.
You may want to check this thread:
FDRS/PTS VIN check
2024 Lariat, it appears my truck defaults to 100% brightness and the 726-42-01 was also set with the x2x2 value. I tried changing the value to 10% and noticed no change on the DRL.
You might double-check your values or you bought a used truck that someone modified. I have As-Built data on over (80) 2022-2025 Lightnings of all trim levels and every one of them has:
BCM 726-42-01 x0x0 xxxx xx--
BCM 726-38-01 xxxx 0Axx xx--
EDIT: Hold on, you were asking about this last year - sure you didn't change your values then and forgot? ;)
