Unannounced 2025 changes (backup beep)
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Not sure, I have a '22 Lariat SR. I kept the speaker around just in case. It can be plugged back in as needed.
Easily doable on any year, look at my previous post. You don't need to do anything outside the vehicle, just unplug the PACM in the passenger's kick panel.
ryun
Earth
It’s not a great recording, but here’s what it sounds like in my garage. I rolled down the window and recorded it from the driver seat.
Sounds like the single piano keypress that the start of every action movie trailer has.
Athrun88
Toronto, Ontario, Canada
That's for the pedestrian sound, right? Doesn't disable the frunk beep?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Correct, the frunk beeper is a separate item that can just be unplugged. No FORScan needed.
Jesse-Infotainment
2024 F150 Lightning Platinum
The files are different in the 25.. same part number for the PACM as previous years. Probably can flash it with the new file. THere is one change in the as build as well. I may try it and see if the new file has the new sound.
Maineiac12
Iowa
Keep us posted!
wchain
Wes
22 Lightning SR, 21 F150 Eco
Hi Jesse! Any headway on this?
Mike G
N. AL, USA
The reverse sound should be
” Danger, Danger Danger Will Robinson”
IMHO
That would be confusing for me….that’s the ringtone for when my wife is calling me.
Jesse-Infotainment
astrand1
Alex
Studio truck driver
I’m glad I coded that crap out with forscan the day I bought my truck. 🤣
RLXXI
3rd rock
Automotive Technician
Sounds just like my 25 Flash. I bought a plug in harness that eliminates that and the forward sound.
MountainAlive
Massachusetts, USA
Is there a way to put a manual on / off switch for the backup beep? I’d like to keep it most times, but when I’m backing out of my garage at 6am I’d like to be able to silence it.
