TPMS reset vs relearn proceedure for 24 Lightning
daczone
2024 Lightning Lariat
Backhistory: I bought new wheels and tires for my 24 lightning (Lariat trim) (Bought it in March 2025) at my local Discount Tire. I spent a lot of time (spreadsheets) comparing the various wheel and tire combo's that I wanted. I did ION 143 wheels (28 lbs) and Ridge Grapplers tires for the look and they are within 1 lb of the stock wheels and tires. The dealer couldn't get the offset (ordered 18) they only had 0 offset available which is a 18mm poke. Anyway they look FANTASTIC and drive so much better than the stock wheels and tires. Noise is minimal and range has not changed for me. I am getting 290 miles on a 90% daily charge.
Ford F-150 Lightning TPMS reset vs relearn proceedure for 24 Lightning 1749064936553-21
I wanted to keep my OEM wheels and tires intact, so I didn't remove the factory TPMS's and transfer them to the new wheels.
First they installed the wrong TPMS sensors (315 Mhz instead of the 433 Mhz), so that was a return trip. They swapped them out but could not get them programmed. So I ordered a set of OEM sensors and still they couldn't program them.
I have a AUTEL TPMS tool, but also have a cheap Amazon "WAKE UP" tool. This is all you need and the proceedure seems to be confusing as there are 2 listed.
The Turn the Ignition ON, press the Hazards 3x (horn honks) and follow the prompts (Scan Left Front displayed on the dash)... etc. This proceedure seems to be a RESET proceedure NOT a RELEARN.
The FIX:
You need to do a RELEARN:
Turn Ignition ON... Do not start and press Hazards 3x
TPMS will prompt you.
With vehicle off, pump the brake once
key on, key off, key on, key off, key on but leave on. (5 presses)
Pump brake once more.
Now cycle the key 3 more times. On the 3rd time it should beep telling you tpms reset has been activated.
Using a TPMS wake up tool IE: This $15 Amazon tool.
Activate each near each valve stem in this order:
  1. Drivers_Front
  2. Passenger_Front
  3. Passenger_Rear
  4. Drivers_Rear
There are no DASH prompts. The horn honks and that is it.
Hopefully this helps someone else. (The Sensors I installed at Motorcraft ML3Z-1A189-D) $20 each on ebay (NEW)
Thanks for sharing the procedure, I've pinned the thread to the section.
WhiteBolt
Ed
CFL
Manufacturing
Where did you buy the motorcraft sensors for $20 ?
I put new Ford OEM sensors on the used 20" lariat rims I bought about 1 1/2 years ago and they were $50 each! Cheapest I could find new on ebay. Ford was seling them for about $50-$80 at the time.
One good thing about my sensors was that I only had to do the hazards 3x to teach the sensor positions. They worked fine after that.
daczone
daczone
Ford Dealer wanted $120 per tire for the TPMS. Search that part number on Ebay. There is a guy that sells them NEW in the packages.
MaintGrl
Marsha
El Sobrante, Ca
The FIX:
  1. Drivers_Front
  2. Passenger_Front
  3. Passenger_Rear
  4. Drivers_Rear
Holy heck, there is a lot to mess up in that sequence, now was it 2 key on's & off, or did I do 2.5 key on's & off's... :unsure: ?
