VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
HAS anyone been able to do a "comfort start" with the FP widget on the lock screen? mine just opens the FP app and then i'd have to tap on the "fan" icon to initiate "comfort start". the widget on the the control center works, i am yet to try the action button.
also, what "map that auto-displays"? is feature on the FP app itself? i do not see it.
Ford F-150 Lightning FordPass 5.21.0 iOS & Android FORD PASS
JCCZ75
Jason
2023 Lariat ER
I think you are using the wrong widget. The widget you would have to use would replace the flashlight or camera at the bottom of the Lock Screen.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Yeah the widget remains unchanged with this update. But you can now put lock, unlock and or remote start control buttons on the Lock Screen (only two controls allowed at the bottom) or on the control panel that you pull down on when the phone is unlocked.
Jackdforme
Barry Allen: 2025 Ford F150 Lightning Flash
What he said... It's a "control" not a widget. Now to get Siri to actually recognize and start car by voice for the win.
VAL.ABAPO
You have to tap and hold the widget. If you just tap it takes you to the FordPass app.
Yep just tried what you said and still just opens the app
Jackdforme
Go to your lock screen, hold tap, edit the custom lock screen you have, if you already have two controls, you will need to delete one of them. Add a control, look for ford, add start, fin.
sstevetx
Steve
abcut973
Anthony
Denham Springs
5.21 hasn't hit my android yet as well.
K6CCC
Glendora, Calif.
But how do you do that? If I'm on the lock screen and hold it, all I get is a message to unlock to edit, but if I unlock, I don't have the lock screen.
Note I am NOT an Apple guy - I substantially dislike this forced on me work phone...
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
What you are looking for starts around 1:28.
K6CCC
Glendora, Calif.
Does not work on my iPhone 13 with iOS 18.5. If I hold on the lock screen, all I get is a message "Unlock to Edit" above the time display. If I unlock, I don't have the lock screen...
Timeless Epoch
Chad
I wonder if your work has your phone locked down.
Another method is you can go into settings\wallpaper and click ’customize’ on the lock screen.
K6CCC
Glendora, Calif.
That is a very good possibility. There are known to be several things that work has locked down.
However your settings > wallpaper method did work.
Thanks
jimparisejr
Jimmy
2025 F-150 Lightning Lariat antimatter blue
Chemistry Professor
I may be missing something but my Ford pass app has not yet updated or is showing an update pending for the 5.21 version. Can someone please educate me on how to?
Go into the App Store and search for the ford pass app. Instead of clicking "open" click on the app title, and the button should read "update". Hope that works!
