Yellow Buddy
- Feb 5, 2022
- Mid-Atlantic
- F-150L Pro, Rivian R1T, Model S, Model X
- Occupation
- Smart Ass
I had a spare set of 18" OEM wheels lying around and figured I would try to use them on my Lariat ER which came with 20" OEM wheels. I didn't want to mess with ForScan so I opted for the 275/70R18 version of the Toyos. Quite frankly, it was the only tire that would work without going to a LT and I would've rather traded someone 18s for 20s than go to a LT tire.
On paper it was perfect, the 116T matched the load rating. It wasn't an XL tire, but with a Max Inflation Pressure of 51PSI this seemed perfect. I was skeptical of the pressure rating without the XL, but I was able to verify it on Toyo's website along with the reseller. Unfortunately, when the tire came in the tire did not match the specs. The Tire was stamped for a Max PSI of 44psi. Technically, it could work as the door jamb reads 42PSI for my truck, but given that I tow and these have a temperature rating of B, I expect these to run closer to 45 PSI cold and 49-50PSI hot.
So, don't make the same mistake I made. The 275/70/18 116T maxes out at 44PSI, not 51PSI as per their specs...
If you want to trade for a set of 18" wheels, let me know....
Update/Edit: After a lot of back and forth, it is confirmed the tires have a max of 44PSI and the specs are wrong in literature. While the tires can technically be used as our doorjambs are under 42PSI, the manufacture cautioned on using them for towing as it will risk a blowout.
Props to TireRack, in researching they were the only reseller that had them listed correctly as 44PSI max. Every other reseller, including some local dealers were using the booklet specs of 51PSI.
