Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
After seeing @ericpullen's excellent work on pulling data from the Ford Charge Station Pro, I've spent a few days trying to a) teach myself how to write a Home Assistant Integration and b) how to bring that into reality and publish it on GitHub as a HACS compatible thing.
I give you "Ford Charge Station Pro Local" which I'm shortening to local_fcsp in Home Assistant.
I'm sure it's buggy as ALL HECK, and please be kind to me ;)
You can see the GitHub here.
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-07-01 at 1.28.27 PM
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-07-01 at 1.28.34 PM
The integration pulls in data from Eric's library, then makes it more human readable. There's logic in the integration to determine if the vehicle is connected, charging, or powering the home. There's also logic to determine if the vehicle is preparing to power home.
Right now, it's only passive, but if we can figure out how to send current change limits to the station in the same way that Eric's figured out how to poll data, we're in business ;).
Vypurr
24' Flash
Very nice! I don't have a charge station, but it's neat to see some local integrations for it
Aminorjourney
Aminorjourney
Nikki
Internet
theUNSTABLE
Ryan
github.com
Cyber Engineer
So much has happened recently with Ford<Thing> and Home Assistant.
I wish I had time to improve things as `fordpass-ha` has been static for a while.
I've talked to someone who did a rewrite of a fork and exchanged information with him, he's been pushing updates and implementing things.
I, as usual, haven't had any time in basically the past year. I have some stuff locally, but don't really use it because its not stable.
There seems to be a good amount of work being done across various Ford things, and seems like a good amount of duplicated work. I feel like multiple people should collaborate on a single thing - but I'm not sure how people feel about that as it may be "their" repo, or "their" code and then BuyMeACoffe things etc.
Aminorjourney
Aminorjourney
Nikki
Internet
I don't have a bunch of time, but this was kind of a holiday project. I've been using the fork of FordPass worked on by Marq - but that's the lovely think about open source/Github. If someone can make a version work when the original coder is unable to work on it, it's possible!
For this project, I'm sad that I've not got any of the networking stuff working other than pulling the Ip address and password for the unit. Maybe someone smarter than me can figure it out! :)
JvdMaat
W. Mass
I moved to this fork of the (your?) Ford pass integration, and it gets lots of regular updates which seem to meet all my desires.
https://github.com/marq24/ha-fordpass
Is that a current good one for fordpass? Based on this forum (some other thread), I am on v1.70 of https://github.com/itchannel/fordpass-ha. But it's been static without any updates. However it does work. So I am... content?
I would love more access though. There's a lot of things in the fordpass app I cannot see in HA..
While I appreciate that it's possible for anyone to work on a fork, I don't appreciate the fragmentation (which version should regular Joe Schmoe end users (like me) use?), and it would be nice if the various forks could be merged into a master version that multiple people can work on.
Aminorjourney
Aminorjourney
Nikki
Internet
It's worth noting that the authors are working together one this :) the one that Matthias has worked on (marq24) is an EV-centric one.
I'd love to see what I did (which isn't all that good) rolled into one of the other projects. :)
Aminorjourney
Aminorjourney
Nikki
Internet
I've been working on tidying the code, and think I've squished one particularly pernicious bug. I've also made a video explaining it in more detail:
Aminorjourney
Aminorjourney
Nikki
Internet
We just tweaked the app a little more to squish some bugs - and also add Power Cut detection.
Yes, I know it sounds weird, but if you have a UPS system for a computer or something, this will help you figure out when a power cut occurs, so you can then activate graceful shutdowns if the HIS doesn't kick in quickly enough.
Aminorjourney
Aminorjourney
Nikki
Internet
Just published v.0.3.0 of this - and I've made some changes to the Power Cut sensor.
I've got it arranged in my dashboard as two cards, but obviously within HA, the world's your oyster.
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-08-04 at 5.30.37 PM
After our FCSP died and a new replacement unit was sent out, I realized that the earlier software for the fcsp has a different status state set, so the new version takes this into account. This is important because if you have the integration and have to get your fscp replaced, the replacement unit may be running OLD software until it gets its OTA update. (it's just taken two days for mine to get up to current system parity).
Also went one step further and cleaned up the version reporting for the Home Integration System, so that now we see a standard V x.x.xx system reported by the inverter. In mine right now, the system is reporting Inverter software 1.1.36
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-08-04 at 5.35.33 PM
Now to the bad bits. There's what appears to be dummy information populating into a Fcsp which hasn't been connected to a home integration system that fools my integration into thinking there's an inverter attached.
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-08-04 at 5.36.51 PM
Ford F-150 Lightning Home Assistant local integration for Ford Charge Station Pro (Passive ONLY) Screenshot 2025-08-04 at 5.37.14 PM
I don't know if @ericpullen has seen this kind of behavior before, but I *think* the best way forward is to write a function that looks for the 'dummy' data (including the vendor and model) and then determining that the HIS isn't attached.
If anyone wants to give it a go ;)
https://github.com/aminorjourney/local-fcsp
FloridaMan85
2022 F-150 Lightning Lariat
You all are awesome for working on this. I've been poking at my FCSP recently and then discovered that so many people much smarter than me have already figured a lot of this out!
My big goal is to get the daily charge session data like we see on the Insights section of the app. I manually log my daily charging kWh and really want to automate that task through Home Assistant. Is there any indication that this data is accessible anywhere?
I found that the Charge Station info in the app loads from prod.swb.ford.com, which led me to this API that seems relevant, but I haven't made any further progress because the app doesn't play well with a MITM proxy:
https://api.vehicle.ford.com/api/wallbox/v1/
theUNSTABLE
Ryan
github.com
Cyber Engineer
I don't have a Home Charger at all so I never directly looked into this. I was primarily targeting the Charge data from the vehicle (the data that shows up under "recent charges"). The first time I found it there was a dedicated API endpoint that just returned everything, and it was great. Then all the API things started happening and it got lost somewhere. Last I tried I found something I thought was the correct option, but it only returned a few entries which I figured was either
- I didn't have enough charges
- Ford Just recently moved data to that API
- Data was reset at specific time
- other annoyingly difficult thing
My current VERY hackey solution, which I'm still fighting myself on feature creep (I WANT ALL MY DATA), and probably doesn't work because I barely have any time to check if it is even working is I wrote a custom custom HA component that essentially watches all of my fordpass sensors and then logs them to my database. Its supposed to detect charges and do some other things and update different tables - like re-gen braking - battery temp while charging - etc.
Ideally it works and then shows up in my (not yet refined) Grafana dashboard. But I'm scared to look at it because if its not accurate I'll have to find out where and I don't have the time for that :rofl
Welcome to the.....joys.....horrors....experience with the Ford API.
I still want my Zone Lightning controls, but I think those endpoints are dead and trying to find any "new" or "updated" one's wont work anymore :/
I do need a break from my other 4 projects that are driving me crazy so I might have to dive back into this one to see if I can refine some things.
I was planning on going 2 different routes to get the vehicle data removing the API entirely, but that has its own hurdles and issues.
