To repair or not repair
F150Flash
Keith
Goodyear AZ
F150 Lightning 2023
Retired accountant
Any thoughts on this situation. A week ago Thursday I started my 23 Lightning Lariat ER with 21000 miles and got a service vehicle soon message. I looked up the error and found it was a power train fault. I called the dealer on Friday and was told to bring it in. I figured it would likely be there a couple days so i took it in on Monday.
The service guy looked up the error and said it appeared to be related to the shifter module but they would check it out. They called later in the day and said it was the shifter module but they are on back order so I could come pick up the truck. When I picked it up I asked if there was any problem with driving it. He said no but did say he’d seen some where the shifter would lock into Drive or Reverse. Since mine seemed to function fine I continued to drive it.
About 2 days after I brought it home I noticed the error message was gone when I start the truck and the wrench light is gone as well. It’s like it fixed itself. Then today I noticed that I had a sync update on the 17th to 25.2.1.6X. I think that happened after the error went away but I’m not positive.
So my question is do I go ahead and let them replace the shift module when it comes in or assume the truck fixed itself? I’ve always felt original assembly was preferable to repair assembly. Any thoughts?
The Weatherman
Dean
South Central KY
Yes. It’s likely going to crap out again down the line.
Mine is a 2022 and not involved in the CSP and I swapped mine for the rotary dial vs from a 2022 Escape. Not going back.
Replace it.
Warren
Warren
Ohio
F150 Lightning Pro
Carpenter
I am in the same boat. Had the warning pop up a couple times a few weeks ago. Haven't called for service yet, and it no longer pops up. Will still get it in soon.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
I’d definitely say replace since it’d be under warranty. Are u considering replacing it with the rotary shifter?
F150Flash
F150Flash
Keith
Goodyear AZ
F150 Lightning 2023
Retired accountant
I thought about the rotary shifter but I don’t see how the plastic piece comes out. Looks like it’s all one piece including the cup holder
Quite a few videos on it. If you depend on the truck I would still purchase a cheaper used rotary shifter to have on hand as a backup/replacement. If the shifter is the issue and the truck is not drivable and the dealer can't get a new one, you can save yourself until they do. A lot of people have replaced it, you'll figure out how to get the old one out, even if it means just taking the old one out and laying the knob down in the cubby plugged in.
The Weatherman
Dean
South Central KY
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
My Lightning intermittently had the error pop up. Dealer replaced the Shifter and all it fine for now.
rikster63
Rick
Nebraska
2021 Chevy Silverado, 2022 Tesla Model S
Real Estate Sales
I'm in the same situation. I've had the same error message multiple times over the past year, and each time it resolved itself. But I finally scheduled it in for service, and I need a new shifter also. My truck is drivable, and I haven't had a new error message while I've been waiting for the part to come in. But I figure it's better to let Ford replace it now under warranty.
Mike G
N. AL, USA
It’s actually easy enough as long as you watch the video and read my post in the tread: https://www.f150lightningforum.com/...ion-w-3d-printed-rotary-shifter-holder.25541/
Post 468.
Yeah, once you've done it ...you realize it would only take you about 20 minutes tops to do it again if you had to. It's not that hard. Just don't follow the workshop manual about removing the entire center stack and you'll be fine ?
Unbelievable the amount of stuff they want you to remove...when it's entirely unnecessary.
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
“REPLACE” whole truck!
It teases you at first “Yellow/red” wrench light up and goes away.
Then it’s back and tells you to park the vehicle soon or to take to the dealership as it won’t start after shutting off.
So, you now feel as your truck is in shop more than home due to the same “Powertrain” malfunctions.
Had several PTM, total 5-7 times between August 2024 and June 2025, two heater cores, one shifter, one low volt battery, and one voltage regulator. I honestly believed it was leading up to a messy high voltage battery replacement so had to say goodbye!
Hope you get it settled and it never gives problems again.
Ford F-150 Lightning To repair or not repair IMG_2246
Ford F-150 Lightning To repair or not repair IMG_0806
flyct
Jerry
South Florida
Blissfully Retired
Your posting made me glad I leased my current Lightning. That way I can walk away after 3 years if my truck has issues like yours. Hopefully not.
Regardless, I rarely keep vehicles past their basic warranty period. The only exception was a 2015 Lexus RX450h Hybrid. It never was in the shop for issues in the 8 years of ownership. I handed it down to our adult daughter.
