powersln
Lawrence
F-150 lightning
I am trying to login, but it is not working. I am typing in the full serial number, as well as the pin I use to login to M professional. Says it is invalid.
Look at your inverter label. The date code (used for M professional) is different from the PIN which should also be on the label.
tearitupsports
Russell
Cypress, TX
Thank you, that worked. Yes it is pretty sparse. I will compare the Delta dashboard to the Sigenergy one below:
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project 1755202126445-s9
Ford F-150 Lightning My new Ford Home Integration System + Battery installation project 1755202206371-cd
