PSA: Use Vinyl protectants on your Lariat seat bolsters ASAP
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
ford use cheap vinyl so for Lariat people take note. Clean and use vinyl protectants like Chemical Guys VRP or Carpro Perl on the grey parts on our seats. It’s vinyl, unlike the leather part in the seat bottom and the seat back(where your back touches). The plasticizer in vinyl will dry out/age from the sun/flexing with us sitting in it. I was a bit neglectful on my Mustang (2016) and the bolsters started to crack. Feel the grey vinyl area around the bolsters/upper part of the seat with your hands and give it a press, it may feel harder/stiffer than say the back seats which don’t get used as much. The stiffening is the plasticizer leaving the material. VRP will keep the plasticizer in and act as a barrier/moisturizer.
I believe in 2024, Ford as an “eco” move changed out the Lariats seats to full “ActiveX” vinyl too…
CD4TNF
Timely. I was just thinking my side arm rest material was starting to get old and stiff feeling. Would the Chemical Guys VRP work for softening and protecting that?
MichaelCA
MichaelCA
It softened mine a bit. It’s needed regardless to keep it from further degrading. I see that people recommend 303 aerospace protectant as that’s more durable. I just had VRP around. There’s also Koch Top star that I’m also looking at as well.
My Tesla model 3 is older than the lightning but its vinyl is superior and still as soft as new. I hate that ford cheaped out on this
CD4TNF
Thank you for the confirmation and recommendation! That's the fun of car detailing. There's so many products! Time to buy something new to try out.
MichaelCA
MichaelCA
Koch seems to be the most nourishing so I’ll be getting that.
Also, I did two applications, second one after like a day it seemed to help more.
P-38
2024 Lightning Lariat
Just making sure I read this right. The black parts of my seat are leather but the gray parts are vinyl?
I have "leather" seats not active x on my 24, part way thru they switched over
MichaelCA
MichaelCA
Yep. Black parts of the seat is real leather. rest is vinyl. the center armrest is also vinyl.
A sun screen in your windshield will help the cause. It reduces UV and sun exposure.
MichaelCA
MichaelCA
Made a mistake. I believe only the seat bottom and the seat back (the perforated section where your back rests on when sitting) are leather. The black part would be vinyl as well.
MaintGrl
Marsha
El Sobrante, Ca
Should you do this? No. Can you do this? Yes. It works great as long as you disconnect the ground prong on your suicide cord or it will trip the gfi in the trucks inverter. Works well as long as it’s done safely.
Huh? 🤷‍♀️
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
On my 23 Lariat with advertised leather seats, the perforated part is grey and the side strips are black. That being said the majority of the seat is grey in mine. The grey surfaces feel and look like leather. Could it be that the opposite is true in my model where the grey is real leather and the black is the stuff made of murdered Naugah’s (Naugahyde)?
Or do I have a model with true leather seats?
Been using Maguiar’s Leather Conditioner on my seats and they are as supple as the day I bought the truck.
MichaelCA
MichaelCA
The perforated grey area is leather. The bolsters, headrest, upper back above the perforation and the black is vinyl is my understanding.
this is why it’s called “leather trimmed” and not “leather seats”
I may be off but that’s what my research seems to suggest. Maybe someone with more experience can tell us. I know the bolsters 100% are vinyl.
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
My Flash has the ActiveX on the entire seat. So do those products you use leave a slippery residue? I don't want my seats to feel slick.
