- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
* But, let's say that you DID have Cruise Control active
my 2 cents: read to the end "
- having Cruise Control already ACTIVE, and the truck then came to a stop because of 'Stop and Go' Cruise activation, on it's own, WITHOUT your intervention, and WITHOUT you applying the brakes yourself, IT WILL THEN MOVE FORWARD WHEN THE VEHICLE AHEAD MOVES FORWARD, as it is designed to.
- ONE PEDAL is NOT a part of Cruise Control, and therefore is NOT suddenly overridden or released simply because the Cruise Control activation button is pressed. ONE PEDAL's design is to APPLY the brakes, CONSTANTLY, and until the DRIVER PHYSICALLY presses the GO pedal to release the braking.
Some thoughts:
A) you allowed ONE PEDAL to bring you to a stop, completely, while it HOLDS, whether behind another vehicle, or not. you then 'accidentally' applied the GO pedal, which released the brakes. This would not, though, 'suddenly' create some type of increase in movement or speed, either, as the ONE PEDAL would still be doing it's job, and would still SLOW and BRAKE the truck, immediately, when you came OFF the GO pedal.
B) while in ONE PEDAL, and at a complete stop, and while NOT applying the GO pedal, you accidentally pressed the CRUISE CONTROL 'middle' button, which activates any FORMER speed setting, and THEN you also accidentally pressed the GO pedal - this 'could' override the ONE PEDAL, and create a sudden increase in speed, although I think even this would not activate the former speed setting and 'suddenly' start to try to get to that speed, on it's own.
C) with FORWARD RADAR WARNING in effect, it's doubtful that any of these would happen with another vehicle in front of you, IF you have the settings of 'AUTOMATIC BRAKING' for this feature, versus just an Alert.
D) if you actually did NOT have ONE PEDAL active, as you assumed, and brought the truck to a stop on your own, with AUTO HOLD in play, you might THINK you had ONE PEDAL active, although it was ONLY Auto Hold, and that could create a situation where the truck would then move forward, IF you accidentally released the Auto Hold by pressing the GO pedal... while it shouldn't then necessarily SUDDENLY lurch into an accelerated speed, if you are in 'NORMAL' drive mode, with little regeneration, it might SEEM that way, when you are caught off guard.
E) if you actually did NOT have ONE PEDAL active, as you assumed, AND you had CRUISE CONTROL active, AND Cruise Control brought you to a stop behind the vehicle ahead of you, then IT is controlling the BRAKE PEDAL, similar to Auto Hold, although it is NOT Auto Hold, and yes, you could then ACCIDENTALLY hit the GO pedal and cause Cruise Control to 'prematurely' release the brakes and move forward, although, again, since the Cruise Control is still active, it would sense the vehicle ahead, and create it's OWN braking action, unless you STAYED on the GO pedal.
* But, let's say that you DID have Cruise Control active and the system brought your truck to a stop behind a vehicle ahead. You then accidentally hit the Cruise Control button, TURNING IT OFF> This action would NOT release the brakes, as the truck is already at a STOP, but now, since Cruise Control is no longer active, if you accidentally hit the GO pedal, even for a slight 1/2 second, it would RELEASE the brakes, and, especially in NORMAL drive mode, the truck might feel like it was 'lurching' forward, and there would be NOTHING TO STOP IT, until YOU apply the brakes.
while it may seem obvious that even employing "Collision Warning" system, which typically might be to STOP the truck, on it's own, if it senses an impending collision, if you are already CLOSE ENOUGH to another vehicle, from a stop, the system may think that you are OVERRIDING the warning system, which is possible.
several times my truck has 'suddenly' braked, with an onscreen alert warning, although the vehicle ahead was already 'turning' out of the way, or was not really as 'close' as the system might make it seem, and my applying the GO pedal kept the truck in motion, and effectively OVERRODE the physical braking Collision action...
Some thoughts:
