New guy- just ordered today. Charge Station info needed-driveway charging?
jppritchard
JP
Fairfax Station, VA
2014 Jeep Wrangler, 2016 Ford Explorer
Hello,
After "reserving" a Lighting another lifetime ago ( $100 May 2021), I FINALLY received the green light from Ford that I could actually order a 2023 Lighting PRO. I just placed the order, and the dealer sent it to Ford.
However, I just realized our garage is too crowded already, and my wife's car won't give up it's coveted garage spot.
Just how far will the charging cable go from the charging station? My truck will be relegated to the driveway, probably 20 or 30 feet away from the where I was thinking of installing the charger.
Also, I haven't been paying attention, but couldn't help but notice Ford's "Personal Offer" program while lurking today. What's the criteria for this? It seems pretty mystical, the Internet manager at my Local Ford Dealer was as non specific and non-committal as possible while discussing.
I have the same situation here - Garage is for my wife’s Explorer and I have my vehicles in the driveway. I have the charger on the outside of the house - it is rated for outdoor service - and I have about 15’ run but the cord may got 20’. I recommend not to stretch it.
Ford F-150 Lightning New guy- just ordered today.  Charge Station info needed-driveway charging? IMG_2126
Ford F-150 Lightning New guy- just ordered today.  Charge Station info needed-driveway charging? IMG_2125
tidemacedo
Aristides
F150 lightning
Hello,
Congratulations, it’s pretty exiting news. Yeah my FCSP has 25 feet cable. However, it came with my truck and I’m planning to replace it by a Tesla wall charger because it doesn’t charge my wife’s tesla and several other members here had the same issue. For some reason the FCSP doesn’t communicate with Tesla protocol. All types of adapters and DYI things were tried and not have success.
From the NEC….
Ford F-150 Lightning New guy- just ordered today.  Charge Station info needed-driveway charging? IMG_0578
If you see any EVSE with a cable longer than 25’, make sure it’s UL listed.
PreservedSwine
Fort Myers
2023 Lightning
If anyone is curious, the nice little cover in the above post is an RV port cover. I have used several to set up things where I would rather have the actual plug on the inside, yet the option to pull things outside too.
Amazon RV Port cover
Thanks for the tip- that's exactly what I ordered. I needed to educate myself with some youtube on how to drill a 3 5/8" hole saw through cinder block- but in the end it's absolutely perfect, and functions properly. I needed to cut the back end off the two RV port covers (impossible to tell once installed) so the charging plug could slide through, but man these just make the install nice and clean.
I swear this truck rides better than my Jag.
Reactions: JRT
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
Like others, I have my charge station mounted near the door of the garage. And unlike others, when the slab was poured it dropped off at the same side so I can leave the cable on the ground and fully close the door without crushing the cable. Rather fortuitous shoddy concrete work.
jwrezz
1996 Ford Explorer, 2006 Subaru Outback Sedan, 2024 Ford F150 Lightning
Teacher/Firefighter
I have a 240v 16 amp charger (to match the plug in my garage) and the cable is not quite thick enough to trip my garage door opener. However, I did change the travel of the garage door prior to doing this. Just barely enough for the rubber to touch the concrete, but it gives enough for the cord. I'd be afraid to go to a 50 amp plug and EVSE "nozzle" as I assume they'd be thicker as well. I can change my garage door closed stop again, but would like to add more rubber to the rest of the door bottom leaving a gap for the cord to pass thru.
@cdherman @snowy_91 Does that RV port have enough opening to fit the nozzle thru? Or do you have a cord that disconnects from the EVSE and can fit thru the port?
jwrezz
Teacher/Firefighter
I should specify, will it fit a J1772 nozzle thru, or only the NACS/Tesla nozzle?
snowy_91
James
Aurora, SD
2023 Lightning XLT SR, 2024 Blazer EV
Yes, it has plenty of room to fit a j1772.
rtw819
Todd
Ohio
'22 F150L Lariat ER, '24 MME GTPE, '19 Niro EV
I just put a hole in the side of my house..
Say, do you happen to recall what part you used for the square surround piece that aligns to the siding around the cord hatch cover? Thanks in advance!
snowy_91
James
Aurora, SD
Lowes and mendards has it in the siding section in a variety of colors.
