Traconesu
- First Name
- Patrick
- Aug 23, 2022
- Quad cities, Illinois
- Ford lightning platinum
- Occupation
- Retired
I'll try that. As I mentioned I never use Fast chargers. Most my charging is done at 7.2 kwh from my solar system to 80-90% unless I need it quick or not enough sun then I use my 80 amp charger. I'll charge it to 100% using my 80 amp charger. Let it set an hour or so then check my SOH. I was only down to 36% so this might not work as I don't like discharging much lower than that. Regardless I'm not real concerned about the SOH because I know it has to be better than what's showing. I've had the 3 defective modules replaced. Approximately 26k miles on it now. A little over 8k miles a year. With 5 yrs left on warranty I expect maybe 79k miles by then an the way I discharge and charge I expect my battery to last long after that.Yes. In fact the slower the charge the better.
