Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
I have been babying my battery a lot more than you have but my SOH is worse at 98%.
I've got a terrible SOH. I suppose it's because I never DC fast charge. Vehicle is at 36% SOC. Showing 103 mi range left. At 70 mph I'm usually getting about 2/mpk. At 55 mph usually 2.1-2.3 mpk. My 2022 platinum has always been pretty constant at those mpk ranges.
Ford F-150 Lightning How Much Battery Capacity And Range Has My Ford F-150 Lightning Lost After 3 Years and 38,000 Miles? Screenshot_20250927_080528
Run your battery down below 10%, let it sit for a few hours, then charge in one single charge event to 100%. I bet you will see a dramatic difference in your SOH
Just to clarify…..this calibrates the SoH measurement by balancing the cells. It doesn’t change the true SoH.
You should also let it sit a few hours once back to 100%.
Good points to make, specificslly that it only calibrates the value, although I dont believe "balance" is what determines SOH. Cell variation, well, varies. I have not seen this impact my SOH, although I have not monitored the relationship closely. More so balance is a pack construct, degredation is per cell. Balancing is at the pack level.
I believe SOH can be directly measured by monitoring the internal resistance of the cell. Not sure how they would do that other than monitoring temp changes during heavy use or high speed charge events though.
Traconesu
Patrick
Even if I only charge with a 17.2 kwh charger, I don't use fast chargers. I don't believe paying the public chargers prices.
Traconesu
Patrick
Yes. In fact the slower the charge the better.
I'll try that. As I mentioned I never use Fast chargers. Most my charging is done at 7.2 kwh from my solar system to 80-90% unless I need it quick or not enough sun then I use my 80 amp charger. I'll charge it to 100% using my 80 amp charger. Let it set an hour or so then check my SOH. I was only down to 36% so this might not work as I don't like discharging much lower than that. Regardless I'm not real concerned about the SOH because I know it has to be better than what's showing. I've had the 3 defective modules replaced. Approximately 26k miles on it now. A little over 8k miles a year. With 5 yrs left on warranty I expect maybe 79k miles by then an the way I discharge and charge I expect my battery to last long after that.
electricpig
Tim
Northwest Arkansas
If you are driving so few miles, why are you changing to 100%? At least that is what I sounds like, maybe that's not the case.
Maxx
Sorry for late response. I just saw your posts. That is indeed very low for the age of your battery. Are you sure you are not running the car scanner in demo mode?
If it is real reading, I don’t have the personal experience to say why it is so low. My DOD (Depth of Discharge) was very low 40%-60% SOC and when I did a road trip that included 100% charging and DCFC, my SOH bumped up by 0.5% so I can’t explain how 10% drop can be attributed to software estimate to be that far off.
Has Your battery been spending a lot of time at SOCs near zero or hundred? Or has it had many hot days? They really don’t like heat. I just came back from a trip. DCFC took the battery temp from 82F to 106F. I drive in Sport mode right after DCFC charging, it seems like it cools down the battery faster (lower threshold for cooling system to kick in). I also try to park it in the shade anytime I have the option.
Next time you charge to 100% (when you see virtually no power/current going in to the battery). Check to see how close battery power is to what total available power is supposed to be for your pack size if it was new. If the KWh you see is 90% of the KWh for a brand new pack, that 90% SOH is real. if not, a piece of software or hardware is lying to you.
p.s. Regarding the look of your car scanner pages, you can make your own custom pages and put any sensor data In those pages with different colors and looks.
Traconesu
Patrick
My longest trips are once a month 120 mi round trip. I normally make 1-2 trips into town a week totalling lest than 60 miles a trip. I seldom drop below 60% SOC and charge no more than 90% but usually to 80-85% SOC. I will occasionally charge to 100% when I drive my 120 mile monthly trip. It often takes me a couple of days to charge back up to 85% because I usually use solar to do that and only charge my truck after my solar batteries are fully charged. I usually charge at 7.2 kwh.
Traconesu
Patrick
I never get close to zero SOC. Seldom to 100% soc and never sets that way for more than a day. Max temperatures don't look bad at all. After charging from 36% to 100% at 17 kwh my SOH still showing 90.5%. 131 kwh battery only showing 126.08 kwh of energy.I guess I'll try taking it down to near zero and charge to 100%.
Ford F-150 Lightning How Much Battery Capacity And Range Has My Ford F-150 Lightning Lost After 3 Years and 38,000 Miles? Screenshot_20250928_083244
Ford F-150 Lightning How Much Battery Capacity And Range Has My Ford F-150 Lightning Lost After 3 Years and 38,000 Miles? Screenshot_20250928_082845
Ford F-150 Lightning How Much Battery Capacity And Range Has My Ford F-150 Lightning Lost After 3 Years and 38,000 Miles? Screenshot_20250928_083919
Maxx
126 KWh of energy supports that SOH is real. The only thing I can think of to cause it not be real is that if you captured it immediately after displayed SOC hit 100% and didn’t wait until it is fully charged. My battery (standard pack), takes near 1 KWh per % for most of charging but many more KWhs from 99%-100% and more after.
Your module variation looks good so there may be other reasons your batteries internal resistance has gone up. If you get 126 KWh out of it, and your long trips are 120 miles round trip, just enjoy it knowing you still have many years left on that battery warranty. I have never felt like I needed more than 98 KWh. On my recent trip, I was fast charging between 20/30% to 80% and that gave me 120 miles of driving between 1/2 hr stops. The length of stops and drives were perfect for us.
I know the number may look disturbing comparing to everyone else. Frankly I didn’t like my 98% when others where reading 100% but if the truck is driving fine, don’t let numbers take away from your enjoyment.
sorry I can’t be more help in figuring out what causes the low SOH.
Traconesu
Patrick
I waited until the next day to check my SOH and it was still at 90.5. I'm going to try one more thing in a day or so. I'll run my home off my truck until it gets near zero using bed 240 receptical. The way I have it wired it powers my home thru my solar inverters which allows me to regulate the load on my truck to just below the 7200 watts keeping my solar batteries topped off while also running everything in my home. Then I'll recharge it to 100%. But I'm not really too concerned about my SOH, more curious about it though.
Be sure to leave it sit undisturbed several hours at both ends.
More detailed info here.
