My home electric bill has basically doubled in the past 4 months! WTF is going on?
RLXXI
3rd rock
Automotive Technician
Doing my part to get out from under the light bill. I can run the house all day and night when sunny, just takes a couple days to recharge the battery array.
These sun trackers pull in the max amount of power compared to a static roof mount, have one of those as well.
About half way where I want to be as far as panels/trackers, the truck tipped me over where I wanted to be in storage capacity. Hope to have the new one producing this weekend.
Ford F-150 Lightning My home electric bill has basically doubled in the past 4 months! WTF is going on? 54909160553_72f4caf7e4
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
When they installed the "smart" meters here (2004 in the south of Ontario, 2010 in my part of NW Ontario) the main change was Time of Use (ToU) billing- allowing different rates at set times of day, to encouage load shifting to evenings ie washer/dryer after 7:00 pm resulted in some cost savings per month.
In 2019 when I first got into planning a solar installtion the ToU rates with very low overnight rates allowed the numbers to work out for me even during winter months where solar was never going to power all my loads.
To ensure I NEVER back feed the grid from my solar/battery/inverter installation, the only connection between the utility and my home battery set up is an AC-DC transformer for overnight winter battery charging.
In other words, my home is always powered by the batteries/solar, and the utility is only used to power a back up DC charger, not to directly power loads, and the utiltiy doesn't connect to my inverter at all, only to the DC charger via relay and control system.
{one exception: I have a circuit directly from the Utility panel for 48A EV charging when needed}
VTHokies
Jason
‘26 Chevy Silverado EV Max Range
We finally got our solar hooked up today. Now we have to wait for the inspector to come out and inspect. We also have to wait for our electric company to come out. We are really excited!!
You’ll love it, I’ve had my panels for 7 years now and I haven’t had to pay an electric bill since!
Scorpio3d
SS/IBA car wash owner
Counterpoint:
I installed solar about 10+ years ago that offset 80% of my usage. After buying an electric car, I installed a secondary system to cover 100% of my usage. The solar system covered themselves in price within 5 years due to state and federal incentives.
I ended up installing minor improvements over time to the house and now my electric bill is negative and decreasing as the rates increase.
I couldn’t make ICE more economical unless I moved to Texas and installed a personal oil well..
Yeah, we all have oil wells in our backyards here🤣😂🤣 the problem is you also have to put in a refinery to make fuel.
I installed solar a few months after getting the truck and that was based on $.10 kWh rates, (I had been researching for a couple of years prior)but also realizing that the rates were going to increase because our grid was so screwed up and that was before AI went bonkers so my payback(ROI) is looking better every day!
Robert
NW Ontario Canada
Contractor
it is a rewarding feeling to have a 'power plant' of my own building, at my homested, heating the buildings (heat pumps) powering my well pump, charging the Lightning.
Aside from other benefits, it is just satisfying to be self sufficient, and self reliant.
Lightning Rod
Lightning Rod
The North Coast
2023 Ford Lightning Lariat ER
PROGRAMMER
So, no one else's energy bill has skyrocketed in the past year or so?
This subject has been pretty quiet lately. :unsure:
22legit2quit
2024 Ford Lightning Flash ER
Not at all, is that what you’re seeing? I’m in the south/midwest so I don’t think the local economy here would support that. The top 11 states for energy costs are blue AF (with exception of Alaska) but I’m sure most people knew that anyway.
jamelski
Sacramento
2024 Lariat
Nope going 2 ev home was the best thing ever. The amount of money we save every month on gas pays for itself.
just had a rental 1.5 turbo bronco sport for 2 days the same driving I do with my lightning cost about 5 bucks in electricity. I spent over 70 bucks in gas.
Robert
NW Ontario Canada
Contractor
I would say my EV and 70mile/day normal driving moved my 1,000kWh per month to nearly 2,000kWh. ie confirmed, double
however as @jamelski points out, the "not-gas" driving is far far less money out of the household overall than pre EV paying for power and gasoline.
In places with low cost electricity and high cost gasoline, as long as you can charge at home overnight it is golden. Places with low overnight ToU rates makes it even cheaper.
K6CCC
Glendora, Calif.
No question, my electric bill has gone up - totally expected. Particularly after I retired and am no longer able to get a lot of free charging at work. Now the vast majority of my charging is at home.
With that said, my cost per mile for the first year of ownership is WAY down. Even with SoCal high electric rates, the Lightning is a little over 1/4 the cost per mile of my old truck. I was spending about $500 per month on gas and in twelve and 1/2 months, I have spent $1,750.96 for electricity.
Carieth
IL
tesla model y
Also, lately I've been thinking less about rates, as I've increased my income. I came across https://online-casinosbe.com/review/wolfy-casino/ and decided to try it. I got a bonus for a game I found there and actually won. I was surprised, but it works.
Smart use of ToU rates and isolation. The DC-only grid connection approach is clever for avoiding backfeeding and maximizing independence!
