Original owner of 22 lariat need help please
Vegas
Robert
Henderson NV
22 lighting ext lariat 22 mache ext prem
This what it showed than and still does to date .
Ford F-150 Lightning Original owner of 22 lariat need help please IMG_0407
Jesse-Infotainment
2024 F150 Lightning Platinum
If they manually updated.. THen it was postponed. Since Ruged has your vin he can see if indeed they did the updates in FDRS.. then you can ignore the Software update tab in the vehicle.
FDRS and the OTA side is not linked. You can get an OTA for an Update that has already been installed manually via FDRS. The update will run the interrogator and see the current version nd then either call the update successful or cancel it and it will show as incomplete ..
Vegas
Robert
Henderson NV
This is the sequence of what happens . I make sure I have good WiFi . Than I go to the software update screen . Pix 1 . Than I hit the update now it says to turn off car and secure the truck. Which I lock . I watch the my passenger window and it counts down it get to zero then it says on the screen it preparing update . Than the car makes some noises and clicks and a few minutes later I see thru the screen that the update has postponed. That the cycle see pix 2 .
Ford F-150 Lightning Original owner of 22 lariat need help please IMG_0405
Ford F-150 Lightning Original owner of 22 lariat need help please IMG_0406
Vegas
Robert
Henderson NV
When he is online again maybe he can rerun the vin I sent him and he see what the dealer head technician did and suggestions
@Jesse-Infotainment Unfortunately, with my watered-down PTS access, I can no longer see vehicle history to see what the dealer did or not. I can also no longer see the software updates tab to see what strat his BCM is on compared to what the OTA wants to send him.
@Vegas The SoC and battery capacity being reported to the cloud seems to be fine. I am not sure what this message "unrecognizedFields":"\"updateTimeInSeconds\":358" means or if that has something to do with why the OTA is not installing.
Ford F-150 Lightning Original owner of 22 lariat need help please 1762616481694-su
If you have FORScan, try pulling the module details of your BCM to see what strategy it is on. According to PTS, you should have AAT and this OTA wants to install AAJ. If you already have AAJ installed, then the dealer updated it.
Ford F-150 Lightning Original owner of 22 lariat need help please 1762616680699-go
The problem with the battery disconnect for 20 minutes trick is that I have seen that cause an OTA trigger to get canceled. Because to me, there is no clear-cut reason why this OTA is failing, I would try disconnecting the battery to see if it helps or not because clearly, it does not want to install anyway. The last 6 OTA's that have been sent to you have all failed, so something different needs to be tried.
Ford F-150 Lightning Original owner of 22 lariat need help please 1762617076581-m1
Vegas
Robert
Henderson NV
After my last try 30 minutes it didn’t install it had a new message I never saw before . See below . The frunk update not installed but this message appeared
Ford F-150 Lightning Original owner of 22 lariat need help please IMG_0414
The battery SOC reported to the cloud was inaccurate in my case...
The 12V battery needs to by 85% or better from what I have read or the/some updates will get delayed until it reaches that level.
A lot of threads about OTAs and low battery.
Do what they say to charge it up - just driving it for a couple hours as Ford suggested did not work for me, but putting it on my FCSP overnight to charge from 70% to 90% did the trick.
So here's my 2 cents:
- You don't need WiFi at all. Your update is downloaded already, you don't need any connection.
- Your 12v is the issue. You haven't disconnected it that I see as recommended. Or, put it on a charger (passenger panel connections) until it's fully charged.
Vegas
Robert
Henderson NV
I will put it on charger but I am unable to disconnect it because of issues with age and a disability I can not reach it to take off the right frunk liner . I have the left panel off where I can hook up my charger overnight if you think if it will work . I did drive it after the new battery install for 5 hours of highway driving.
If the SoC being reported to the cloud is wrong, then the BMS data quality is compromised and PTS will show you that is the case. No harm in trying a BMS reset once the battery is at 100% charge.
The OTA failed; that's why you got that message. It failed due to a software mismatch, so it is possible the dealer did update it and the OTA failed because there was nothing to update.
Ford F-150 Lightning Original owner of 22 lariat need help please 1762630087847-g
Jesse-Infotainment
You should be able to see updates in Vehicle history
It's been over a year, but...as I recall one of the SOCs that appeared on the Ford web site was not the LV battery soc but was the HV soc and there was some forum confusion about that and how to find the 12v battery soc or if it was even displayed.
There was an issue with the original BMS sensor for the HV battery, not the LV battery, and a new sensor was installed.
There was a lot of screwy' data at the web site, for example my tire pressure was reported as slightly over-inflated lol:
Ford F-150 Lightning Original owner of 22 lariat need help please tire pressure - OMG
So that's what I should have said/meant about it not being an accurate LV battery soc.
On reflection, maybe that was not what was meant by "reported to the cloud" in these recent posts?
There was this from Ford at the time I was having issues getting OTA's:
Everyday Battery Confidence
Ford electric vehicles have an eight‑year/100k‑mile high‑voltage battery warranty,** but there are still a number of ways to help you get the most out of every charge:
  • Precondition your vehicle and battery in extreme weather
  • Keep software updates current by setting a schedule to automatically update overnight
  • Maintain a 12V connection in order to perform software updates
  • Use 1‑Pedal Drive to help increase regenerative braking†
https://view.msg.ford.com/?qs=e6e2b...82d8dfdd61d7cdb3c8968a1895c034db57849ad280d2d
I highlighted the "Maintain a 12V connection in order to perform software updates" to make the point about the LV battery and OTAs.
Also this:
12V BATTERY 35AH
CHANGING THE 12V BATTERY
If the 12 volt battery needs servicing, see
your authorized dealer.
CHARGING THE 12V BATTERY
Your vehicle has a high voltage to low
voltage energy transfer feature that keeps
the 12 volt battery charged by the high
voltage battery. If the 12 volt battery level
is low, the high voltage battery transfers
energy to the 12 volt battery when the
vehicle is off.
Of course what that doesn't mention is the algorithm used which originally was such that it waits for the 12v battery to go below 40% for 48 hours before kicking in with the DC-DC transfer.
From P034, the body builders doc attached.
While ignition status is off, DC-DC is normally off and 12V battery supports the 12V loads.
While ignition is off, if 12V battery reaches 40% state of charge, then vehicle waits 48 hours , before the DC-DC transfers 300 Watt-hours of energy to recharge the 12V battery. The HV power comes from either HV battery or wall power while on plug. If the 12V battery state of charge reaches 30%, then this HV to LV energy transfer happens immediately with no delay.
Note:
• This system was designed to recharge 12V battery while the vehicle was left parked for many days
either on or off plug or occasional drain from customer usage. The 12V battery will wear out if this
energy transfer is completed daily due to aftermarket loads draining the 12V battery down to 40% or lower.
I believe they adjusted that algorithm in an update recently to better maintain the 12v battery?
If there is some place on the Ford web site where we can see an LV battery soc, I'd be interested in a link.
Hook to blue circled places per this forum post:
Ford F-150 Lightning Original owner of 22 lariat need help please where to connect neg for battery charger-info
Note the negative is connected downstream of the BMS connection - or connect the negative to a body ground.
