Configuration files wanted
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
I am trying to discover what modules in the Norwegian 2023 Lariat SR that is unoriginal. So far I have found the:
- BECM switched from XXX to NL38-10B687-XA
- TCU switched from PL3T-14H076-FNF to NU5T-14H074-CHE
And possibly:
- RTM - Radio Transceiver Module from XXX to FT4T-15K619-AB (or any part that enables DAB radio and removes SiriusXM)
Anyone with a 2023 Lariat willing to share their configuration file?
RLXXI
3rd rock
Automotive Technician
And possibly:
You can d/l the asbuilt (original) files for your truck on this link with the vin#. https://www.motorcraftservice.com/AsBuilt
hb.sagen
hb.sagen
Henning
Norway
But the module verssions are not listed in the as built files? Like in the file in the first post?
RLXXI
3rd rock
Afaik, the versions they keep on file are the originals. Files as they were built.
hb.sagen
hb.sagen
Henning
Norway
Yes, and I have them. But the german engineers switched components from other vehicles. The BECM is from an E-Transit, and the DAB module is from something else, maybe a MME?
I want to check if other components are switched as well.
Jesse-Infotainment
2024 F150 Lightning Platinum
The files are in the as build.. as the very bottom.
Jesse-Infotainment
RTM is the module that handles the Remote key fob and TPMS
ACM handles DAB
The file you posted is from Forscan. On the Motorcraft As-built site, you have to download the file to see module info. The module info is at the bottom of the file described by <NODEID> tags. For example, the F188 tag is what Forscan refers to as Strategy and CarScanner refers to as ECU Software Number. I don’t know which Fxxx corresponds to Part Number though, maybe @Jesse-Infotainment or @rugedraw knows.
Things may be different than when you were a tech. The As-built files on the Motorcraft site get updated with current module versions and any parameters you modified. The file will not be the original file when the truck was built anymore.
Forscan changes won’t be reflected immediately but eventually the truck phones home and lets the Motorcraft site know the updated configuration. I worked with a member once and it took a couple of weeks for his Forscan changes to appear on the As-Built site.
FDRS sessions seem to update the Motocraft As-Built site very quickly. The one time I did FDRS updates, the As-built file on Motocraft reflected the change within minutes.
I download the As-Built file each month for my truck - that's how I confirm that OTA's and dealer service actually changed the module software version in the truck. See my post above on how you can use the As-built file to determine the software version of each module.
RLXXI
3rd rock
That's definitely different from back in the day, it was what ever it was built with, no such thing as calling home except for ET. That gives a whole new meaning for saving ones asbuilt from day 1, more important than ever.
Good 411. (y)
P.S. Still a tech just not with Ford any longer. :bandit:
I know the info is in there, but I do not know how to find it in the ab file other than doing a control F and searching for it. However, if you knew what you were looking for, there would be no need to look for it. Best I can think of is let's says you wanted to know the info for the GWM, you would get the ab data and scroll to the bottom and look for 716 where the NODEID portion of the data starts for that module. The info would be somewhere in here:
Ford F-150 Lightning Configuration files wanted 1762790286432-35
Good 411. (y)
Yea, all vehicles capable of OTA's sync themselves with the mothership randomly and with every OTA.
Keep in mind the original AB data in some cases is supposed to change with OTA updates (like WAL, BC 1.4, etc). In some case, a frimware update can add new lines of code in a module that weren't there when the vehicle was first built. Your original ab data can eveutually become a problem if you revert back to it after some time.
hb.sagen
hb.sagen
Henning
Norway
I made a comparison chart with a 2023 Lariat from the US
NodeIDModuleMy Car2023 LariatDifference
6F5OBCCDS-LK98-14G568-ALDS-LJ98-14G568-ASDifferent base part (LK98 → LJ98)
7D0APIM - SyncDSNU5T-14G670-BBDSPU5T-14G670-EFDifferent prefix and suffix
730PSCM - Power Steering Control ModuleDSNB3V-3F964-AADSNL14-3F964-ABDifferent prefix/base code
737RCM - Restraints Control ModuleDS-MB3T-14B321-AADS-ML3T-14B321-CBDifferent prefix/base part (MB3T → ML3T; AA → CB)
6F0BCMC - Body control module CDS-MU5T-14D068-EADS-MU5T-14D068-EAidentical
6F2SODCMC - Side obstacle detection CDSML3T-14H031-AHDSML3T-14H031-AHidentical
6F3SODCMD - Side obstacle detection DDSML3T-14H031-AHDSML3T-14H031-AHidentical
706IPMADSPJ6T-14G647-AGDSPJ6T-14G647-AGidentical
707DCACBDSNL38-14G620-BDDSNL38-14G620-BDidentical
725WACM - Wireless Charging ModuleDSNL1T-19J235-ADDSNL1T-19J235-ADidentical
731RFA - Remote Function ActuatorDSNU5T-14G617-AFDSNU5T-14G617-AFidentical
732GSM - Gir shift ModuleDSML3P-7P427-AHDSML3P-7P427-AHidentical
733HVACDS-NL3T-18C612-AACDS-NL3T-18C612-AACidentical
746DCDC - Direct Current Converter ModulkeDSLK98-14B227-ABDSLK98-14B227-ABidentical
750PACM - Pedestrian Alert ModuleDS-MU5T-14G113-ADDS-MU5T-14G113-ADidentical
764CCM - Cruise Control ModuleDSML3T-9G768-AEDSML3T-9G768-AEidentical
765OCS - Occupant Classifiacation ModuleDSNL1B-14B422-AADSNL1B-14B422-AAidentical
775RGTM - Rear Gate Trunk ModuleDS-MU5T-14B673-AFDS-MU5T-14B673-AFidentical
783DSP - Audio proceessing moduleDSH1BT-18B849-ARDSH1BT-18B849-ARidentical
791TRM/TBM - Trailer moduleDS-MU5T-19J294-AKDS-MU5T-19J294-AKidentical
7C7ACCM - Air Condition Control ModuleDS-NL3H-19F611-AADS-NL3H-19F611-AAidentical
7E0PCM - Powertrain Control ModuleDSNL3A-12A650-AUSDSNL3A-12A650-AUSidentical
7E7DSNL38-7S008-BBDSNL38-7S008-BBidentical
760ABSDSPL38-2C219-AADSRL38-2C219-BCPrefix & suffix differ (P→R, AA→BC)
724SCCM - Steering Column Control ModuleDSML3T-14B522-BDDSRL3T-14B522-BAPrefix and suffix differ (M→R, BD→BA)
727ACM - Audio Front Control ModuleDSJX7T-18K810-ATDS-JX7T-18K810-AXPrefix/Suffix differ (missing hyphen, AT → AX)
754TCU - Telematic Control Unit ModuleDSMU5T-14H074-ABRDSMU5T-14H074-ABSSuffix differs (ABR → ABS)
6E3FHCM - Front hatch control moduleDS-PU5T-14F008-ACDS-PU5T-14F008-ABSuffix differs (AC → AB)
751RTM - Radio Transceiver ModuleDSML3T-15K619-ACDSML3T-15K619-ABSuffix differs (AC → AB)
734HCM - Headlamp Control ModuleDSNL1B-13C148-AGDSNL1B-13C148-AESuffix differs (AG → AE)
7C4SODL - Side obstacle detection module LHDSML3T-14H031-AHDSML3T-14H031-AGSuffix differs (AH → AG)
7C6SODR - Side obstacle detection module RHDSML3T-14H031-AHDSML3T-14H031-AGSuffix differs (AH → AG)
744DSM - Driver front seet moduleDS-MU5T-14C708-AJDS-MU5T-14C708-AGSuffix differs (AJ → AG)
7C1CMR - Camera module rearDS-ML3T-3G590-ANDS-ML3T-3G590-APSuffix differs (AN → AP)
740DDM - Driver Door ModuleDS-MU5T-14B531-ANDS-MU5T-14B531-ARSuffix differs (AN → AR)
741PDM - Passenger Door ModuleDS-MU5T-14B533-ANDS-MU5T-14B533-ARSuffix differs (AN → AR)
7E6SOBDMC - Secondary OnBoard Diag ModuleDSNL38-7P120-BEDSNL38-7P120-BFSuffix differs (BE → BF)
7E4BECM - Battery energy control moduleDSNL38-10B687-BFDSNL38-10B687-AHSuffix differs (BF → AH)
716GWM - GateWay Module ADSPU5T-14H474-CABDSPU5T-14H474-GACSuffix differs (CAB → GAC)
720IPC - Instrument Panel ClusterDS-NL3T-1A292-CAEDS-NL3T-1A292-CAFSuffix differs (CAE → CAF)
6F6LDCMADSNL7A-13B626-CEDSNL7A-13B626-CDSuffix differs (CE → CD)
6F7LDCMBDSNL7A-13B626-DEDSNL7A-13B626-DDSuffix differs (DE → DD)
7E2SOBDM BCCM - Battery Charging moduleDSPK48-10B689-FADSPK48-10B689-AFSuffix differs (FA → AF)
726BCM -Cody Control ModuleDS-NU5T-14B476-AAGDS-NU5T-14B476-AAMSuffix differs (AAG → AAM)
6F1DCACA - Direct Current/Direct Current Converter ADSNK38-14G620-ABDSNL38-14G620-ADVariant code differs (NK38 → NL38; AB → AD)
RLXXI
3rd rock
I know the info is in there, but I do not know how to find it in the ab file other than doing a control F and searching for it. However, if you knew what you were looking for, there would be know need to look for it. Best I can think of is let's says you wanted to know the info for the GWM, you would get the ab data and scroll to the bottom and look for 716 where the NODEID portion of the data starts for that module. The info would be somewhere in here:
What year model did they start calling home?
In the case of the F150, in 2021 when they went to Sync 4 and started getting OTA updates.
Yeah, the file is formatted XML so can be a pain to read normally. I created a macro in Excel that will decode an ab file and let me see F188 values for all the VINs in my database. If I wasn't lazy I would try to make a program like As Built Explorer that would show that.
I mainly look and compare the F188 parameter as that seems to correspond to the "software version". Do you have a cheat sheet on what the other Fxxx numbers are? Are they just version numbers of other configuration files that get loaded (side-loaded) or does one of them represent the hardware part number?
