Infotainment Column Shifter Conversion
2024 F-150 Lightning Flash
I went ahead and bit the bullet and paid the eye watering price for the column conversion kit because I like it enough to pay the premium for the custom harness and mounting bracket that infotainment provides along with the parts. After installing the column shifter and running the harness I finally start up the truck and to my absolute disappointment I get a "SHIFT SERVICE FAULT SERVICE REQUIRED" error on the dash. Despite this I am able to shift into gear and move forward and backwards, go into neutral, and the M button even activates the 30 minute neutral. The shifter also automatically moves into park like the regular shifter does when you open the door without a seatbelt on in drive. Using Forscan I see a bunch of codes that the gear shift module is not communicating and even removing the codes they return again so something is definitely wrong. Turning off the truck and walking away from it and coming back actually causes it to freeze up and the dash screen and radio stays black despite pressing the on button. The truck basically gets bricked with the DRL lights on until I use the emergency latch and open the frunk and disconnect the battery and reconnect it (not sure the exact cause of this but it happened twice during my trouble shooting). After one of these events the truck will refuse to turn on even if you reconnect the stock shifter unless you clear all the codes or disconnect the battery for a minute again (I discovered the cause of this was disconnecting the gear shifter right after turning it off, it seems to cause the entire truck to freak out. Gonna try to avoid doing that). Connecting the stock shifter or even a rotary shifter I get none of these codes. I have a strong feeling this is probably an issue in the shifter itself or the harness they provided is not wired correctly somewhere.
I am mostly writing this to see if anyone else got the kit and had any success installing it without issue. I have a 2024 F-150 Lightning Flash trim.
I have reached out to infotainment so hopefully they get back to me by tomorrow. In the mean time I reinstalled the center console shifter.
UPDATE: 11-17-2025
After a not so great customer service experience over email with Infotainment followed by a much better experience over the phone from Daniela ( I should have just called from the beginning) I got the correct part and I have sent back the incorrect shifter. Turns out I got sent a 2024 shifter which has ford's TRON encryption which was causing my truck to freak out and basically brick itself until I disconnected the 12v battery. Now that I installed the 2023 column shifter it works perfectly without a single issue. The M button even acts as the 30 minute neutral button from the stock shifter so all functionality is retained. The plus and minus buttons that would have been regularly used for changing gears in an ICE truck are non-functional though they do say they are working on adding functionality in the future. No codes after driving and shifting a lot over the weekend. The bracket that attaches the column shifter seems sturdy and well built. I will say the part looks like it was 3D printed but its clearly high quality. I was able to flex it and remove it after having put it on and noticed no cracks or warping. It feels like a production level piece and the fact that I could take it off and put it back on and notice no damage to the piece itself gives me confidence it will last.
Overall really happy with how it came out and I definitely recommend it if you are really wanting a column shifter over the stock shifter and want more space in the center console area.
Ford F-150 Lightning Infotainment Column Shifter Conversion PXL_20251114_220216577
Ford F-150 Lightning Infotainment Column Shifter Conversion PXL_20251114_220212564
On their website (under Things to Know) says it is "unoperable" on Lightnings
Ford F-150 Lightning Infotainment Column Shifter Conversion 1762908085273-2g
josephalbert0425
I appreciate the answer but what that's actually referring to is the manual shift buttons. The plus/minus on the gear stalk since those are unused on a lightning. In compatibility it lists the lightning all the way to 2025 as compatible and in the installation video they are doing it on a lightning. My issue isn't with those buttons. It's the error code it's throwing up despite functioning like it should from what I can tell.
Jesse-Infotainment
2024 F150 Lightning Platinum
@josephalbert0425
THe harness you got, there is a connector that has a 4 pin connector that should have a looped connector on it.. is that present?
Also make sure none of the pins didnt push out in the connector at the column shifter.
josephalbert0425
@josephalbert0425
The harness I received does not have that looped connector.
Jesse-Infotainment
josephalbert0425
SO is that connector there and just open ended?
Its a connector looks like this
No sorry I should have been more specific, theres nothing there at all. The wiring harness I received just goes straight from one end to the other. It looks like there's a thicker portion in the harness where that connector should be (at least I'm guessing from having watched the installation video).
Ford F-150 Lightning Infotainment Column Shifter Conversion PXL_20251112_015630651
Jesse-Infotainment
Ok.. I thought they had the production harnesses already. Its probably a bad solder at that connector at the Console shifter.. I didnt even know we were shipping them yet.
Ill get with them tomorrow and have them get you a harness.. Those connectors on the console shifter side are pcb board and really are delicate.
Jesse-Infotainment
@josephalbert0425
Can you get me the part number on the shifter. They also may have sent you a 24 shifter.. which would be wrong for a 24 lightning as they dont have TRON
THey should have sent you a 21-23 shifter.
If you have a RL3T part then it is wrong and that is the issue
josephalbert0425
@josephalbert0425
just checked and the part number starts with RL3P-3G594-AG (edited to add full part number in case thats relevant)
Jesse-Infotainment
Yeah that’s the issue then. Makes sense. They saw 24 and sent a 24 shifter. 24 ice trucks the shifter is part of the encryption and lightning doesn’t have encryption in 24-25
Message me your order number and I’ll get them to reach out tomorrow and get you fixed up with the correct part
josephalbert0425
Thank you so much. I will note that I ordered it as soon as they sent an email out for the product launch but at that time they did not have a lightning specific option, just model year. I'm guessing that is where this whole mix up stemmed from. Either way I'm super grateful that you took the time to help me this late in the day and blown away by this level of help from infotainment.
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
I get the rotary knob conversion, but what reason or improvement in operation could there be for a column mounted selector?
josephalbert0425
nothing besides the open tub in the center console for whatever you want. mostly just personal preference. I didn't really like the rotary shifter in the center console when I tried it out. I just like the column shifter more.
