Driving mode defaults back to Normal even when selecting ok to continue last driving mode
Spope
Steven
2024 f150 lightning flash ER
Construction
I have noticed since the last OTA update my 24 flash defaults back to normal driving mode after a restart even when selecting continue last driving mode. Previously it flashes up for about 5 sec if you dont hit continue last mode it will default back to normal. I usually drive in sport most of the time. Now even if I select continue in last driving mode it changes back to sport but after reversing out of my driveway when I put it in drive it defaults back to normal. Anyone else experiencing this issue?
jamelski
Sacramento
2024 Lariat
Yes glitch. I did voice memo to ford. Something always breaks with their OTA 🤣🤷🏻‍♂️
chriserx
Louisiana
Weird, the pop up is waaaay too fast imo, by the time I even notice it it's already gone and I gotta go back to controls. I like the accelerator mapping for sport but I like to mostly coast to a stop where possible. Kinda wish they'd tie the aggressive regen to it's own setting, might even let them skirt the DOT regs unless it remaps traction control.
Anyway, are you pushing it early in the window or late? Just curious cuz when I'm proactive about pressing it I haven't had a problem with keeping it on.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Second thing on my startup checklist. Push Start button, grab seatbelt with left hand, and punch the OK button with the right. I too like the regen drag in Sport mode, kinda like an old standard tranny
brirr76
Midwest / KC
2024 F150 Flash / 9.6kw + Max Tow - Midwest / KC
Yes! Same issue. I let them know about it.
Spope
Spope
Steven
Construction
Yes I've tried pushing it as soon as it pops up and waiting till it almost disappears either way it just defaults back to normal mode. It only takes about 10 extra seconds to switch manually its just a minor annoyance.
Adventureboy
It should just stay in the drive mode you left it in - ideally by driver profile. The only exception is off-road mode, which locks the differential and affects TCS. Most regions mandate that TCS be fully enabled at startup (ie. turn Off-Road mode off automatically.)
Spope
Spope
Steven
Construction
brirr76
Midwest / KC
Any reply? I still have the same issue are you still having this issue?
Yes, I still have the same issue and I need to switch it EVERY day, multiple times a day. It's become memory muscle... put on seatbelt, put phone on charger, then switch to sport.
Brian @ Ford said about a month ago " it is a bug and should be fixed in an upcoming OTA. ".
Spope
Spope
Steven
Construction
Ok same here thank you so much for the response. Hopefully they get it fixed on the next OTA. Still love my truck just need to iron out a few kinks.
chriserx
Louisiana
Wait until you encounter the short shutoff, no popup, straight back to normal one. I'd say it's spicy, but it's pretty bland.
