Adventureboy
As with many things ChatGPT, it doesn't tell the whole story. The Depth of Discharge (DOD) is a significant factor in determining the rate of degradation and is perhaps more impactful than the target SOC, given our top-protected packs. Draining your truck to 10% then charging it to 90% weekly, is harder on battery degradation than charging from 75%-90% daily. As the cells charge and discharge, they expand and contract, causing tiny microfractures in the cells that cause degradation. The deeper the discharge, the more microfractures are caused per kWh discharged (it's an exponential scale, not a linear scale). ChatGPT doesn't capture this significant detail in the numbers.Day to day its 80% in the summer and 90% in the winter. 100% whenever I think i will be putting more miles on that day
Regardless of the safety buffer built into the battery a lower percentage increases pack lifespan. Quick chatgpt answer here for an ER that drives 15k per year.
Charge to 100% daily (≈1.88% annual loss)
• After 10 years: 82.7% remaining → ~17.3% degraded → ~108.4 kWh usable
• After 20 years: 68.4% remaining → ~31.6% degraded → ~89.6 kWh usable
Charge to 90% daily (≈1.63% annual loss)
• After 10 years: 84.8% remaining → ~15.2% degraded → ~111.1 kWh usable
• After 20 years: 72.0% remaining → ~28.0% degraded → ~94.3 kWh usable
Charge to 80% daily (≈1.36% annual loss)
• After 10 years: 87.2% remaining → ~12.8% degraded → ~114.2 kWh usable
• After 20 years: 76.0% remaining → ~24.0% degraded → ~99.6 kWh usable
