Moonroof leaking water
explosive0
2024 F-150 Lightning Platinum
2024 Platinum owner here. I've had water leaking through the moonroof causing musty smell. Also had the recall/TSB work done on the moonroof, however, it seems to be getting worse.
Took it to a drive thru car wash today just to get a decent handle of how much water was being let in, and it seemed like a lot. Is this normal water drainage/leakage?
AZT9
Peoria, AZ
I’m no expert on the subject but it is designed to “leak” into channels that then drain down the A and C pillars to the ground. Your video seems excessive tho.
Open your roof and make sure the seals are intact. That's an excessive amount of water, should be easy to tell where it's coming in.
FloridaMan655321
Banned
Banned
Banned
1973 F100, 2024 Flash
This is certainly not a Lightning issue as it seems all (maybe not 100%, but...) F150's since they went to aluminum have sunroof leakage. One main reason I opted for the Flash, even if it meant having clothe seats, which is fine for me.
explosive0
I was reading up on the ICE forum about conditioning the seal and found this stuff was HIGHLY recommended. Just treated my seals today and the difference is pretty big
https://a.co/d/hzp8R3O
Actually have this from my Tesla Model X days. Brings back memories. lol
Pre-aluminum...
The roof drains are likely clogged.
taraafico
ali
f150 Lightning
self
Wow, that’s a lot of water! Mine is ‘24 Lariat and I was planning to go to the dealership and do the “Trough Assembly “ , but seeing what they did yours I’m so hesitant now. 25B08 is the campaign number, I’m not sure if I want to do the repair cause I don’t see a problem now.
Bigisland Guy
Ed
So Cal
Retired Old Dude
Also have a 24 platty, performed CPS work and they found a clogged drain. Being in the southwest Its a great idea to lube the seals with 303 car seal maintainer.
flyct
Jerry
South Florida
Blissfully Retired
What is “CPS work”?
MaintGrl
Marsha
El Sobrante, Ca
MaintGrl
Marsha
El Sobrante, Ca
MaintGrl
Marsha
El Sobrante, Ca
If I remember correctly, there was a post here that the OP went into detail how they cleaned and conditioned their sun/moon roof track/drain/seal
Bigisland Guy
Ed
So Cal
Retired Old Dude
Meant to type CSP, Fords Customer Satisfaction Program, (type of recall that they deam less than total recall)
A lemon law attorney explained to me their basic process and it works something like this: TSB Tech service bulletin < CSP < Recall. When I needed to lemon my first Lightning.
