B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
Thank you buddy. Appreciate your quick reponse on the same.
I will retry this tommorow and post updates.
From the first post of this thread about ⅔ of the way down:
SCCM *Only if you swap the left hand steering wheel switch for the one that includes the follow distance change
724-03-01 03xx xxxx
Naveen
Naveen
Louisville, Kentucky
F150 Lightning 2023 XLT- 311A
Hey @ZSC100 , Good Afternoon
I tried this approach today Morning and seems like its still not recognizing the new switch.
This is what i did
1) DIsconnect 12V battery for 1 hour
2) Do the steering wheel switch swap
3) Update SCCM module with new values
4) Restart CAR
Its still not recognizing the new switch. Here are the new SCCM values
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1763484559332-nv
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1763484583711-xl
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1763484609329-6
Can you please advise what I might be missing ?
Thank you
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1763484125151-uq
ZSC100
Zach
Tulsa, OK
Electrical Engineer
This is what i did
4) Restart CAR
Thank you
You say you put the old switch back in? What I'd try is put the old switch back in, get it working, that way you know that you are doing things correct physically. Then with the new switch in and working, change your part # to the new part. Verify the original stops working? Then Proceed to swap in the new part.
Naveen
Naveen
Thank you for your reply. Yes i did put the old one back yesterday using the same technique and it worked fine. Then after reading your comment yesterday about FORSCAN changes , I tried installing the new one today morning with the same technique.
I have disconnected by 12 V battery now and would plug it back after 2 hours to see if that has any effect.
I'm quite sure im doing the installation correctly as i have done it now 3 times :-(.
1) Install new one (didnt work)
2) Install old one back (worked fined)
3) Install new one again (not working until now )
Naveen
Naveen
Seems like Battery reset didn't do any change. Still not working.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yea, you never need a battery reset. I've never once done that.
Confirm you have the original button set in and working. Change the part # to the new one in the SCCM, does the original button set stop working???
IF YES you know the new SCCM part # change has taken effect.
Swap in the new button set and it will work.
Naveen
Naveen
Good morning
Im seeing these errors after following steps listed above for left switch installation..
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT Screenshot_20251119_110638_Chrom
This leads me to believe that the New Switch is indeed faulty. Old one is working fine.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yeah, open circuit, That's not good.
Is that the only DTC you get if you leave the button set unplugged,?
I'm conflicted that it could know the module is wrong, but also the module is not working??
Unless these are DTC set at different times.
Naveen
Naveen
Good Morning
FORDPARTS sent me a new one after i told them this is faulty. I was able to install the new one without any issue.
Man, it was supposed to be simple :-( but faulty part led me to a rabbit hole. Thank you, folks, for your inputs.
Well appreciated.
MNG-HTOWN
Mohamed
Houston, TX
2023 F-150 Lightning XLT
Hey everyone.
I just got this mod working FINALLY. After about 2 days of work lol as I had to add wires and I am not the best at electrical work. But I got it all working last night thanks to @ZSC100 and did the steering wheel buttons too, so all is good BUT ...
This morning, I noticed a frunk service fault and the frunk has completely lost all power. Hitting the button on the key, frunk or inside the cab do nothing with no beeping noise. The outlets and frunk light do not work. Hitting the emergency release button does nothing too.
I know I must have done something. I checked the one connection we remove when taking out the frunk tub and it is seated correctly.
Anyone know what I can check to see what happened??
THANKS!
MNG-HTOWN
Mohamed
Houston, TX
Try unplugging frunk connection harness and put it back again.
Did that already. I am assuming that is the connection harness that must be removed to take the tub out. I removed and re-seated it twice already :(
B177y
I looked in the fuse box under the hood but did not see anything out of the norm. What fuse should I be checking for the frunk?
I don't know which fuses power what. Check in the manual on the truck screen or downloaded from the Ford website to help narrow your search. There are a couple of different fuse locations in the truck.
