galstaf
- Jul 20, 2025
- North Georgia
- 2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
- Occupation
- community offgrid training
Subject: 2022 ER Lightning rejecting 80A charging on Tesla Gen 2 EVSE?
Hey all!
I’m running into a frustrating issue trying to get my 2022 Lariat ER to accept its full 80A charging capability. I’m using a
Tesla Gen 2 80A Wall Connector
with an 80A rated NACS-to-J1772 adapter.
The Setup:
Is there a way to see the actual J1772 negotiation logs? I want to know if the Tesla EVSE is rejecting the Ford's request or if the Ford is seeing something it doesn't like in the pilot signal at that amperage.
IIs it possible to use Fordscan or some other app to see if I can pull any relevant error codes. Has anyone else encountered a hard "fail" instead of a down-negotiation when trying to hit 80A?
Hey all!
The Setup:
- Truck: 2022 Lariat Extended Range (equipped with dual onboard chargers for 80A/19.2kW support).
- EVSE:
Tesla Gen 2 Wall Connector
(80A max). - Wiring: 100A breaker with <10ft of #4 gauge for the final connection to the EVSE.
- Thermal Camera Check: No heat issues at the breaker or wiring; Plus the error happens within 10 seconds
- When the EVSE dip switches are set to 80A, the truck "thinks" for about 10 seconds and then the EVSE flashes a red error light. No HV contactors ever click in.
- If I down-clock the EVSE dip switches to 64A, the truck charges perfectly.
- A test Cybertruck pulls its max 48A from this same setup without issues.
