Frode Vike
This is the front.Possibly, you have to remove the black plastic trim piece on the lower front side of the rear wheel well. On the rear part of the wheel well I used the lower inner most hole, removed the push tab, pushed the flare in and up and pushed the tab back in. You don't remove the plastic trim piece in the rear. Can you post a picture of the mud flap from the inside of the wheel well?
This is the back.
