Battery Maintainer / Trickle Charger
JimmySasquatch
James
Indiana, USA
23 Lariat ER
Has anyone permanently installed a battery maintainer / trickle charger using an SAE plug? I’ll be spending about 3 months abroad this summer, and from the research I’ve done it sounds like the recommendation is to charge the HV battery to around 50% and keep the 12V battery on a trickle charger.
I was thinking about installing something like a flush-mount SAE port so it’s easy to plug in the charger while the car sits. Something along the lines of this:
Amazon.com: ELECTOP Rectangular Connector Power Socket Sidewall Port, Weatherproof Quick Connector Solar Panel Flush Mount SAE Plug Adapter, 12AWG SAE Cable for Solar Generator Battery Charger (2 Pack) : Patio, Lawn & Garden
chriserx
Louisiana
I fully intended to install a magcode port until I got my new EVSE.
Yes, many of us have. Search the forum to see one of the several threads here about putting trickle charger/maintainers on the battery and how to make it easier by adding a charger wire:
https://www.f150lightningforum.com/forum/threads/charging-12v-battery.16979/
Here is what I did - an SAE plug at the charge port, on a fused wire to the battery compartment.
Ford F-150 Lightning Battery Maintainer / Trickle Charger 0-My Lightning-IIMG_6004-SAE at charge port
Be sure negative is down stream of the BMS sensor as shown because the truck does coulomb counting to keep track of the battery SOC:
Ford F-150 Lightning Battery Maintainer / Trickle Charger IMG_6024-battery BMS sensor
Use a maintainer with an AGM mode, like the NOCO Genius1 for example.
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
I just had the brake recall done and in talking with the tech, he recommended topping off the 12v about once a month. For that interval, I'll just do it the regular way.
For storing more than 30 days, Ford recommends leaving truck at or near 50% charge and disconnecting the 12 volt battery.
Adventureboy
There is a guy on the MME forum who did that. He mounted it right in the charge port area.
I permanently mounted a 5 amp Noco on the back of the battery door and tied it to a weatherproof 120v RV style inlet in the grill area. That way I can charge it with any 120v cord. In the event the battery ever goes dead (heaven forbid), I am an extension cord away from getting up and running.
transportkevin
Kevin
Mid Missouri
2023 Lightning
I thought the truck maintained the 12 volt while plugged in to the level 2 charger at home. Am I wrong???
Adventureboy
It does not. It only charges the 12v while the HVB is being charged. If you are already at SOC, even if plugged in, the 12v gets drawn down.
