ABRP Premium - what's the advantages?
K6CCC
Glendora, Calif.
Background: I have used A Better Route Planner on my desktop computer a few times to help plan a route, and I have it loaded on my Android. However without upgrading to premium, as far as I can tell you can't really do much with ABRP on your phone (or more importantly on the truck display) en route. I do have an OBDLink LX Bluetooth 3.0 OBD2 reader that works very well with the Lightning.
I have a 1K mile or so trip coming up in a week or so and do plan on starting the 14 free trial of ABRP prior to the trip. What capabilities and features does the OBD & ABRP actually get me and how do I use them?
And yes, unrelated to ABRP, before anyone suggests it, I have turned on a month for BlueCruise and Tesla charging...
Thanks
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
Thanks
The two most valuable features are the ability to view ABRP through Carplay and the use of the dongle to integrate battery information into the app. If you just using ABRP for route planning, you don’t need premium. If you want to use it for in route navigation, then it is probably worth the money. Just like a Tesla supercharger account, if you only road trip occasionally, you can spend $5 for the month and cancel when you don’t need it.
K6CCC
K6CCC
Glendora, Calif.
Or in my cast Android Auto.
So far, I have barely even used it for route planning.
That is useful to know.
Personally I run it on my phone, using Google Maps on the screen. The only reason I use it is so I can see if I am meeting, exceeding, or falling behind the expected SOC at any given mile.
A good perspective.
So far I have taken about a half dozen trips that were long enough to require charging on the road. For the most part I have used a combination of PlugShare.com and the Tesla / E.A / bpPulse apps to back up what PlugShare said. I do not ever expect to need ABRP to actually determine the route I am going to take. My Dad taught me to read maps about 60 years ago and I was an active pilot back in the days before GPS so I DO KNOW how to read a map and plan a route! And to this day I like studying maps. When I have played with ABRP on the computer I mostly already knew where I was going to charge, and I did not always agree with what ABRP suggested. Maybe some of that is me not knowing what I am doing...
I figured that this upcoming trip might be a good opportunity to try out ABRP Premium and see what it really can do en route and see if it would be worth buying in the future. I also have a tentative 3K mile trip in the summer.
abcut973
Anthony
Denham Springs
I use plugshare, free ABRP and Google waze for my road trips. ABRP for planning my charging stops that I double check with plugshare before hand. I do have a dongle linked which reads the car data in realtime and update the route accordingly (speed reduction suggested or else). During the drive I have Google maps on the screen and ABRP on my phone.
I believe the premium subscription gives you traffic data and android auto display in the truck.
Jim Lewis
San Antonio, TX
I went on a 3600-mile round trip from San Antonio, TX, to London, Ontario, and back by two different routes this past summer. The ABRP Premium subscription worked well for planning and driving the trip. However, for local routing between in-town locations, I used Google Maps as the routing, and the display of routing was usually better within a town than with ABRP. https://www.f150lightningforum.com/...enty-to-love-little-to-hate.30854/post-570205
abcut973
Anthony
Denham Springs
Yeah i'm not a big fan of ABRP display.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
May be a little late in the conversation on this but I have used ABRP premium for several years and just finished a 1400 mile trip using it. In general it it has gotten better over the years. Now that it pulls the battery percentage info from Android Auto I don't have to have the OBD plugged in anymore. This last trip however after installing a major update with all sorts of new capabilities I didn’t double check default settings, so on my trip first major leg it had the adjust speed option turned on. I didn't catch it and when I told it to pick an alternative charging location because I knew I had range to go further it ended up directing me to a location under construction(not active). No problem if thought and hit the another location and I happily started driving, only realizing on the highway I would need to drive at 60 miles per hour to make it with 3% left.. So I had to back track and arrive at 9% to a slower more expensive Georgia Power charge point.. charged at a max of 79kw and had a very extended lunch and turned off the adjust speed option. All worked well from there. NOTE: I am going to try using ABRP to plan my next trip and share/transfer to my android auto and run the plan from there to see how that might work.. just discovered that... comments, now that ABRP does better with real traffic situations and takes into account weather conditions as well as pulling data direct from Android Auto it's pretty close to Google maps.. not exactly there but pretty close. To me worth the 5 euros aka $ I pay for it a month.
potato
BC, Canada
2023 F150 Lightning XLT ER
Biggest benefit is probably motivating the developer to keep it going. Won't hurt to throw some money their way once in a while.
I suppose Rivian has deep pockets but in general that's how I look at software.
