tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Cypress, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
I have this exact setup. There is no reason to change anything. I just have my existing SolarEdge inverter tied into the Sigenergy load hub. The Sigenergy app monitors it exactly the same as direct connected solar.Those of you with Sigenergy experience, I already have a 5 kW SolarEdge inverter with just over 5 kW of solar with Solaredge Inverters. I know It would be cheapest to leave this alone if I add the Sigenergy gateway/transfer switch, the Sigenergy Inverter, and the Sigenergy DC charger, but I know the sigenergy inverter has built in MPPTs. Do you have any recommendations on how my system could work if I left the solaredge optimizers and connected the solar to the sigenergy inverter? Or would I have to also buy and install the Sigenergy microinverters to make this work? And is this even worth it at all or should I just leave the solaredge system connected to my main panel and leave well enough alone.
Even AC coupled solar works with the system, and can run on or off-grid correctly.
