The Weatherman
- First Name
- Dean
- Apr 20, 2023
- South Central KY
- 2022 RR F150 Lightning Lariat ER, 2020 Explorer PL
- Occupation
- Retired
Your AI response lost me atNo matter what the source is, most of us will be limited to 40amp 240v. Not 48amps. a 14-50 outlet can only safely supply 40amps to the EVSE. That may equate to 8.6kwh/hour. My AI overview:
Al Overview
A 40-amp, 240-volt Level 2 EVSE delivers about 9.6 kW of power. This adds
approximately 0.16 kWh of energy per minute (or 9.6 kWh per hour) to your
vehicle.A Autel Energy +2
Using this charger while driving is functionally impossible because EVs cannot be
driven while plugged into an AC charging station. However, even if you could, the
energy added would not be enough to sustain highway driving.o
이
Energy Added per Minute: 0.16 kWh
Range Gained per Minute: At 2 miles/kWh, this recovers roughly 0.32 miles of
range per minute.
Why it wouldn't "help much": Highway driving typically requires about 25 to 35
kW of power to overcome wind resistance and weight. This means your 9.6 kW
charger would only supply about a third to a fourth of the energy required to drive
at highway speeds, rapidly draining the battery anyway.
If you are looking into how to efficiently charge your EV, I can help you:
Estimate your daily charging costs based on New Jersey utility rates.
Calculate charge times from 0% to 100% for your specific EV model.
Compare Level 2 charger installation options (such as hardwiring to 48-amps) using
the EnergySage Level 2 Guide.
Let me know what you'd like to explore next!
‘Using this charger while driving is functionally impossible because EVs cannot be driven while plugged into an AC charging station.’
Because obviously it can.
