Taxman's Lightning Chronology
I've been busy the past month getting my race bikes engine rebuild finished, today picked up fresh racing fuel to complete the stationary heat cycling of the engines rings & bearings, fire in the hole 4/30/2026 @1400 EDT
First round of heat cycling revealed a compromised coolant hose at the thermostat housing, took the Lightning on a 131 mile road trip to pick up the replacement hose and shrink tubing.
Installed new parts tonight, more heat cycles Friday afternoon.
Ford F-150 Lightning Taxman's Lightning Chronology 1777603874387-ld
Heat cycles completed, bike is prepared for racing, unfortunately while I was thrashing to complete all tasks today and be ready for 5/2, a text-alert came in that Saturday racing is canceled, rain-out.
Ford F-150 Lightning Taxman's Lightning Chronology 1777686355345-cv
I had also been in the process of charging to 100% so that I'd be certain to be ready to roll at 4:30 am, got the trailer cleaned up, all tires including the spares are aired, wheel bearings greased, figured I would take the whole rig for a 30 miles test drive, about half highway and the second half local roads, went from 98% SOC to 83% , ~19.65 kWh resulting in a mixed 1.5 MPK, while on the first leg of 15 miles I was running about 1.1 MPK, which is likely going to be the rate for the full trip to the dragway.
Next event is 5/9.
Also activated EA 25% discount for July, that will help cut costs for the anticipated DCFC sessions at the Tewksbury 350KW site, this location has an 85% max charging limiter, but I only need 80% each visit, one going up to the track, then again on the return trip.
Documenting my current list of OTA updates in the signature.
I'm going to shorten the list of older versions, shown here:
๐Ÿ”ท Diagnostic Improvements on 6/9/26๐Ÿ”ท OBCC-AS.AU OTA on 4/10/26 ๐Ÿ”ทPT-25.13.12 : Charge Port Func. & Cold Weather on 3/23/26๐Ÿ”ทSYNC-25.2.1.6.5.2 - SiriusXM on 3/12/26๐Ÿ”น PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles on 9/22/25 ๐Ÿ”นIPMA-24.204.10.9 Blue Cruise 1.4 on 9/5/25๐Ÿ”นBCM-24.5.1 Frunk on 9/4/25๐Ÿ”นFHCM-24.AC.AD-Frunk on 8/15/25๐Ÿ”นDDM-25.12.0 Smooth Windows on 4/9/25๐Ÿ”นECG-25.2.5.7.1 LVB Performance on 3/20/25๐Ÿ”น10.1.1 - Con & Power Management on 2/1/25๐Ÿ”น10.1.0 - karaoke on 1/16/25๐Ÿ”นECG-24.2.5.6.3 on 12/4/24๐Ÿ”นPU v6.14.0 on 9/6/24 ๐Ÿ”น23-PU1024-6CH-AUD on 4/5/24 ๐Ÿ”น24-PU0105-CMR-FX on 3/20/24๐Ÿ”น23-PU0813-DOR-UP2 on 3/19/24๐Ÿ”น23-PU1113-UNX-DC on 2/29/24 ๐Ÿ”น24-PU0119-DC-CHG4 on 2/23/24๐Ÿ”นPU Improved Diagnostics on 1/23/24 ๐Ÿ”นPU v6.8.0 on 12/22/23๐Ÿ”น PU v6.5.0 on 12/16/23๐Ÿ”น PU v6.4.0 12/11/23๐Ÿ”นPU v6.2.0 10/30/23
Jseis
Washington
We need to start a go fund me account to get your home charging rate up to at least 20-25 miles an hour. Watching the SOโ€™s Mach E charge on a 120V circuit is like watching paint dry. Of course at $.064/kWh Iโ€™m not complaining ๐Ÿ™„. And she drives maybe 5-10 miles a day.
That is no longer an issue, my FCSP is cranking at the 80 amp setting since the fall of 2022.
