So, this was at the end of my driveway ...
jeffcrum
Slidell, LA
2021 F-150 XLT 302A Powerboost 7.2kw Inverter
Computer programmer
I suspect it is mine. Need to find time to get it up and investigate.
Ford F-150 Lightning So, this was at the end of my driveway ... IMG_20210815_154958260
jeffcrum
jeffcrum
Slidell, LA
Computer programmer
Don't we all?
But, this one would have appeared after 20 years without incident.
Not saying it isn't the case. But, unlikely. ?
Merccat
Ryan
2021 Space White Lariat SCAB 5.0 4x2
Lippy
CA
2021 F-150 Powerboost
How do you know it's from your truck?
Merccat
Ryan
In all seriousness it does look like the bolts ford uses. However, it also looks pretty worn. Not only the chips in the coating and spots of rust but the bolt edges look rounded as if it were removed and re-installed a few times or by someone with not quite the right size socket.
I might still get it checked out but my guess is its an older bolt.
66F100Again
Massachusetts
'66 F100, '11 Mustang GT, '21 F150 Lariat
Maybe the bolt got dropped into a body panel or frame crevice during assembly and they couldn't find it, so they installed another one. This may have been rattling around somewhere and finally fell out as you turned into your driveway. (?).
UGADawg96
JAX, FL
302A 157 PB
I guess it depends on how much traffic you get on your street. Maybe the trash truck or pickers or someone else driving through and it bounced ? The thing looks a bit old.
67440dodge
New Jersey
'22 F150 XL on order 67 Dodge Coronet 440
The job ain't complete til there's parts left over...
MRButtler
Matt
2022 Lariat Lightning
They didn't reapply threadlocker, so that serpentine belt is gonna get slack again.
Joneii
Central PA
F-150 Lightning, Tesla MY
You must be part of the Early Access Program. I heard about the next Power Up where the truck will shed parts it deems unnecessary or that you haven’t used in a while to save weight and increase efficiency. You will be seeing the change in your Guess O Meter soon—congratulations!
ICE truck issue carried over from the forum partitioning last year, thread closed.
