Ford needs to let us buy the pro with extended range
Pedaldude
Arizona
Is it really worth the extra $10,000 on the Pro for the Extended Range battery? Or for that matter $7,000 for the other trims?
The standard range pack is 230 miles versus 300 miles on the extended range.
I know that they likely underrated the battery but that's almost $150 extra for every mile of range and you would need to do more math to see how that works out over charge/discharge cycles.
Extended Range does net higher HP numbers from the motors and if I recall correctly, also gets faster charge times. Still, for the average user, the standard range looks like the better deal.
sotek2345
Engineering Manager
The extended range battery also includes the 80A charge station pro in the price, which is a pretty good value!
wingfiry
Ryan
Cleveland, TN
2023 Lightning Lariat ER
The SR is certainly cheaper, but the ER adds not only the additional range, but also the additional onboard charger (1 per battery for a higher sustained charging rate) as well as the 80A home charger. Whether that combination is "worth it" or not is really a matter of personal opinion.
Blainestang
FL
F56, R55, Pro
I agree with you, on principal, but there are LOTS of variables, here.
What is your normal use case? Does your grandma live 130 miles away, so the SR wouldn't make it without charging, but the ER would?
Are you doing lots of LONG trips, in which case the ER's range and charge rate would probably make it a substantially quicker trip?
SR = 44 minutes to add 150 miles
ER = 41 minutes to add 195 miles (or 31 minutes for 150 miles)
So, the ER would save you 13 minutes per stop.
Are you towing often, especially distances >100 miles?
Do you want or need the 80A bi-directional charger? Because it's included with the ER, but would cost maybe $1500 to buy for the SR, closing the price gap.
What will the resale be on SR vs ER? If ER has better resale, that may eat into the savings, too.
All that to say: I'm planning to get the SR because I think the Pro SR is the best deal by far. The XLT ER isn't worth anywhere near $20k more, to me. $10k for the Pro ER if it were available? Maybe. $7k for the ER if a higher trim? Maybe. $20k to go from Pro SR to XLT ER? No way.
fitek
Peter
Washington state
Ford Transit 350EXT
I asked two friends with Teslas about the bigger battery.
One said the big pack is absolutely worth it. He is retired and road trips in his car. I did a 13 hour drive with him once and he is a mad man, driving fast until the battery runs down to zero. He owns a small vineyard and tows equipment with it.
The other is an office worker and said it is not worth it. He can only make it about 200 miles before he needs to take a half hour break anyway. He would put the money into the better autopilot so his commute is less painful. He drove from SF area to us on the Canadian border and took the scenic route, spent a couple days doing it.
My bladder range is about 2 hours also, and the SR seems fast enough. The Pro SR seems like an awesome deal, costs the same as a freakin Chevy Bolt. IMO next meaningful step up would be XLT+ or Lariat and you're spending waaaay more then.
sotek2345
Engineering Manager
Where you live is a big player in this too. If you live in Northern states you need to deal with winter range reduction which can take a big chunk.
biers
Thomas
SW Washington
2022 Pro SR upgraded to ER
It’s on the Ford Spec sheet. Google: Ford F-150 lightning specs pdf
shutterbug
Phoenix
I still think it's just a rumor about not being able to get the ER battery on the pro (general public). there has been no rock solid proof of this that I can find, just people on the internet making statements of such. Of course if it's on the net it must be true right? ?
Everything on Ford's website says it's available and does not stipulate JQ public or fleet only. Just says it's available.
If someone has a link from Ford that shows this is a definitive requisite for fleet to obtain. I'd like to see it.
The spec sheet with this information has been around for 3 months. A copy of it has been posted in this forum earlier.
Ford F-150 Lightning Ford needs to let us buy the pro with extended range 1629330428135
Skynetf150
Skynetf150
Dylan
Buffalo ny
2019 f150 5.0 customized
Construction
That's my problem with the new lightning I'm not paying 20k more to get the higher horsepower and range any price over 55k isn't worth it to me and at that price range cyber truck is better
corytx69
Cory
BMW i3
Everyone has made excellent points. Ford announced they want to do more online business than on the lot, but for the Lightning they are maximizing profit by forcing buyers into trims/equipment they dont want to get the features they do want. Even the pizza chain lets me totally customize my pizza. Why cant Ford say, here's the base model, pick your equipment preferences from our Ala-Carte list. When KBB values your car worth, you pick the options installed to value the vehicle worth. The truck I want will cost more than a current FX4 King Ranch or Raptor and still wont have BlueCruise. I havent bought a new vehicle in 9 years. Do people really put down $40k to $60k now to be able to afford the monthly payments ?
greenne
Nathan
Niskayuna, NY
I think its less about trying to force buyers to a more expensive trim and more about controlling production costs. In general, production is more costly the more trims, configurations(or options) you offer. Its no surprise that Ford is trying to keep the cost production to a minimum given the price point. (As we've discussed at length before, the margins are going to be thin on the Lightning..esp at the lower trim level).
In addition, having multiple options/configurations slows down the number of vehicles Ford can turn out in the short term. I'm sure they want(need) to get as many vehicles out the door to start getting a decent ROI.
I remember a time when you could choose dozens of options, engines, axle ratios, bed lengths, etc. That has slowly been disappearing over time, most obvious with the imports(Toyota, honda,, etc). Many years ago they started making the options few and the trim levels determined what you got.
Blainestang
FL
F56, R55, Pro
This is certainly true for a lot of cases. Perhaps the most extreme is Tesla, who offer only a handful of physical options on the 3/Y : motors (1 or 2), interior color (black or white), just 5 paint colors, 1-2 wheel options... that's about it besides brakes/suspension on the Performance models. I don't like it, personally, because then tons of people have the same exact car (and the color palette is trash), which is boring, but it certainly simplifies production.
That said, the biggest locked option on the Lightning and the topic of this thread can't be explained away by production simplification, because they are still building the Pro ER, they just won't let retail buyers buy it. It seems pretty obvious that it's either just to force people into more expensive trims in order to get the ER battery, or to force people to stick to the smaller battery which leaves more batteries for higher-trim vehicles... or both.
It's a good decision from a profit standpoint, because I think they'll have no trouble selling plenty the higher margin, higher-trim versions and maxing out production. So, I get it as a shareholder, but it's disappointing as a reservation holder.
Skynetf150
Skynetf150
Dylan
Buffalo ny
Construction
I'll probably just wait a year or 2 until all of them come standard with the bigger battery to buy one I'm not paying 62k just to get more horsepower and range vs 39k, my current 2019 f150 5.0 cost 29k brand new I don't care about leather or moon roof or carpeted floors.
ShirBlackspots
Charles
Wichita Falls, TX
2006 Ford F-150 XLT 5.4L
The PRO is a loss-leader....
Ford did say it was profitable, even at $40,000
I made a CT reservation dispite it’s look, not because of it (it has grown on me over time though) and I agree with OP that once you are in $50K range, CT is a better deal.
The PROs of the base PRO over CT1 for me:
  • More usable bed design and flat roof.
  • full size spare tire
  • Dual motor / 4WD
  • a body and design that has been around (existing after market mods and easy to work on)
  • Don’t have to worry about TESLA haters shooting at my door or throwing rocks at my windows.
  • CT1 is a low priority truck for Tesla that will come online late or may never be built. PRO is more likely.
The PROs of CT2 over XLT at $50K:
  • 6.5 foot bed
  • 300+ mile range
  • Adjustable suspension with great ground clearance
  • 3000 Ib payload
  • holds 6 people
  • Tesla charging network
  • I expect it to be more efficient at high speed with aerodynamic top and bottom.
  • Glass roof
  • standard auto bed cover and tailgate ramp
  • No paint scratches and polishing to worry about
  • If 4680 battery pans out, it may have a million mile battery.
  • A lot of goodies like 4 wheel steering that does not exist or come only as option in lightening.
  • I am not sure if the though body and glass is a Pro or Con yet.
As is, I probably end of with a base Pro simply because it will most likely be available to me earlier.
Tesla said they'll be opening their network to other manufacturers later this year or next.
